18th Mar 2007, 6:07 pm | #1 |
PHILIPS N4307 spare parts etc.
I own a Philips N4307 which is need of some TLC, Seems like it needs a new Vu meter. Anyone know of where i can obtain one? Also the only output I can find is the headphone output via a 6pin din plug. Could this be connected to a line in of say a CD recorder in order to transfer some old recordings?
18th Mar 2007, 7:31 pm | #2 |
Re: PHILIPS N4307 spare parts etc.
I can't help with a VU meter but regarding connection to an external recording device such as a CD Recorder you should find a suitable output on pins 3,5 (linked) and 2 (ground) of the Radio/Gram DIN socket; the output from the headphone socket will be of the incorrect level and impedance for connection to a line level input and additionally will be dependent on the volume and tone control settings on the N4307 unlike the Radio/Gram output. Incidentally if you wish to use the headphone socket for its intended use, i.e. to connect a pair of headphones, 6 pin "domino" to 1/4 inch jack (of the type used on most headphones) should be available from Maplins. Regards Andrew |
19th Mar 2007, 6:45 pm | #3 |
Try Doffery who is a member of the forum he may well be able to supply you with a new VU meter.
19th Mar 2007, 6:50 pm | #4 |
Just a point the Din speaker socket on the back is switched so when an extension speaker is plugged in it cuts off the internal one. I have known these to go open circuit so it doesnt reconnect.
19th Mar 2007, 9:06 pm | #5 | |
Andrew |
21st Mar 2007, 1:11 am | #6 |
all these units will need the drive belt changing, as they turn to goo. If yours is still the original, you'd want to to do this sooner rather than later as the clear up operation is very time consuming and dirty work!
Unless you're planning on recording, (which, on these machines, I have always found to be a weak spot) the VU meter is not essential (doesn't operate in PB) |
21st Mar 2007, 1:55 pm | #7 |
I too have a Philips 4307, rediscovered in parental attic, and as ben predicted the belts have turned to goo. Could anyone advise on where to get new ones and the correct way to fit them? The machine has been in the family from new and worked well at its last outing in c. 1984. Thanks.
21st Mar 2007, 3:03 pm | #8 |
Drive belts can be obtained from Colin Braddock tape recorder centre in Blackpool at a reasonable price, I paid £18 but that was about two years ago but the postal service was very good. Not easy to describe fitting in words but it is very straightforward.
Good luck. |
21st Mar 2007, 3:25 pm | #9 |
thanks Andrew, have left him a message.
21st Mar 2007, 6:30 pm | #10 |
OK James, hope all works out
