Old 10th Dec 2018, 5:32 pm   #1
G6Tanuki
G6Tanuki's Avatar
Default R209 audio amplifier - how is it supposed to work?
I'm doing a bit of repair to my old R209 (a few resistors gone high, leaky decoupling capacitors).
One thing I've always been confused by is the audio amplifier.
it uses two different valves - a 1T4 and a 1S5 - in push-pull. See attachment.
Audio input is via C81 to the grid of V9 (1T4) - the grid of the 1S5 (V10) gets fed seemingly from the screen-grid of V9 by way of C80
Apart from the oddity of using two dissimilar valves (one has a Gm of 0.72 the other 0.9!) how is this supposed to work? Is the screen of V9 somehow generating an antiphase voltage of the 'right' value to allow V10 to make a contribution?
It's not like any other P-P amplifier design I can remember!
G6Tanuki is offline
Old 10th Dec 2018, 5:44 pm   #2
ms660
ms660's Avatar
Default Re: R209 audio amplifier - how is it supposed to work?
RDH4, book page 585:
http://www.tubebooks.org/books/rdh4.pdf
Lawrence.
ms660 is offline
Old 10th Dec 2018, 5:48 pm   #3
ukcol
ukcol's Avatar
I think you have it right. The "triode" formed by V9 with the screen grid playing the anode roll provides the phase inversion for V10. Hardly Hi-Fi but that is not required.
Maybe the lower gm valve is required to prevent the circuit going into oscillation? That I admit though is a totally wild guess.
ukcol is offline
Old 10th Dec 2018, 5:50 pm   #4
G6Tanuki
G6Tanuki's Avatar
Thanks for the info: it may "work" but it seems an utterly crazy bit of design! I wonder what the guys at Murphy had been adding to thir tea the day they came up with it?
G6Tanuki is offline
Old 10th Dec 2018, 5:56 pm   #5
turretslug
turretslug's Avatar
That's worthy of a "freaky Friday" at Philips R + D.....
To be fair, it probably represents an ingenious way of making an efficient, minimum-power and minimum bottle-count AF amp, with one also acting as phase-inverter via its screen-grid and the lower gm of the "slave" valve of the push-pull pair compensating for the slight gain of the first valve's control-grid-to-screen-grid circuit.
I'm quite liking it now....
turretslug is offline
Old 10th Dec 2018, 6:12 pm   #6
ms660
ms660's Avatar
Here's one from another thread that takes the feed from the other valve:
https://vintage-radio.net/forum/showthread.php?t=139740
Lawrence.
ms660 is offline
Old 10th Dec 2018, 6:36 pm   #7
G6Tanuki
G6Tanuki's Avatar
The ingenuity of designers striving for adequate-performance-with-minimal-component-count never fails to astound me.
[I recall a similar circuit using a P-P pair of 6V6, grid drive to one of them, the other grid earthed, and a shared unbypassed cathode-resistor to provide the coupling, so one half is grid-driven common-cathode in the traditional way and the other half is cathode-driven grounded-grid!]
G6Tanuki is offline
Old 10th Dec 2018, 6:42 pm   #8
TonyDuell
That sounds a bit like the well-known 'long tailed pair' differential amplifier in concept.
TonyDuell is offline
Old 10th Dec 2018, 6:55 pm   #9
Ambientnoise
Isn’t it a cascode circuit ?
Ambientnoise is offline
Old 10th Dec 2018, 6:55 pm   #10
G6Tanuki
G6Tanuki's Avatar
Yes I guess you could call it a 'power output' long-tailed-pair load-driver!
G6Tanuki is offline
Old 10th Dec 2018, 10:11 pm   #11
Jon_G4MDC
Jon_G4MDC's Avatar
Haha, as my brother in law is fond of saying "do we like this?"
It gathers opinions for sure..
Jon_G4MDC is offline
