Old 9th Dec 2018, 6:31 pm   #1
G3PIJpeter
Default Unknown R-C bridge [Mullard GM4140]
I bought a nice crackle-finish test device at today's BVWS swapmeet at RWB today (Dec 9th). It was billed as a Phillips R-C bridge of pre-war vintage. Although the valves are side-contact, the components appear more 1950s to me. The magic eye is bright and the sensitivity control works - but I cannot obtain a null with any combination of R or C attached to the top terminals (centre one is earth).
Does anyone recognise this device? Does it have a name? Can I obtain working instructions or a circuit diagram?
All suggestions gratefully received.
Peter G3PIJ
ID:	174268   Click image for larger version
ID:	174269   Click image for larger version
ID:	174270   Click image for larger version
G3PIJpeter is offline
Old 9th Dec 2018, 6:42 pm   #2
Barnmead
Barnmead's Avatar
Default Re: Unknown R-C bridge
I have a Mullard GM140 which is very similar it seems many variations were made have a look here: http://www.richardsradios.co.uk/cr_bridge.html
Richard
Barnmead is offline
Old 9th Dec 2018, 8:29 pm   #3
G3PIJpeter
Many thanks Richard. I knew that someone out there would have the answer to all my questions. I shall now go back to my recent acquisition and try using it according to the book.
Best wishes
- Peter
Old 9th Dec 2018, 10:57 pm   #4
MotorBikeLes
Whilst I know the saying "Replace all caps" is depracated, I think all those black/brown ones WILL be faulty. Check and replace one at a time, then expect it to work correctly. Check the values first though, they MAY be close tolerance, and labelled 1%, 2% or similar, depending on circuit location. The circuit is very likely almost identical to a host of similar ones. For example, Hunts (of known infamy here) made one.
Les.
MotorBikeLes is offline
Old 10th Dec 2018, 1:59 pm   #5
David G4EBT
David G4EBT's Avatar
Looks like someone has robbed it of its magic eye.
Nothing new there then. Shame really, but that's the way of the world.
Test gear generally gets little use, so as often as not, the 'eye' is in excellent condition, and of course worth far much more than the bridge.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 10th Dec 2018, 2:07 pm   #6
ms660
ms660's Avatar
Post #1.
Lawrence.
ms660 is offline
Old 10th Dec 2018, 3:15 pm   #7
David G4EBT
Ooops - egg on face - couldn't see it in the hole on the front panel, didn't read the post as carefully as I should have.
David.
BVWS Member.
Old 10th Dec 2018, 9:51 pm   #8
WME_bill
Unknown RC bridge. Mullard GM4140 or Admiralty type 5000.
I have one of these, the first instrument I acquired.
I still remember the face of the Mullard Executive in 1971 when I went into the Head Office in Torrington Place, Tottenham Court Road and asked for a manual. He kindly received this schoolboy, produced the manual for me, and sent me on my way with best wishes for a successful future.
My version is the GM4140, with the EM4 side contact magic eye, and EF36 and EB34.
I still use it. The electrolytics and the two 0.05 wax capacitors have been replaced, but the standards seem alright still.
This machine is interesting as the scale covers two decades, from 0.1 to 1 to 10, which reduces the numbers of ranges and standards required.
I have fitted a switch to short out the two 85 ohm expansion resistors to give a single decade, which I find easier to read. Using external standards.
And for use with a transformer ratio adapter, based upon a Scroggie design.
Also a neon lamp flasher to test wax capacitors for leakage, which I found very useful when every radio seemed to have TCC paper capacitors for interstage coupling.
I attach the manual and a 1954 specification leaflet.
wme_bill.
WME_bill is offline
Old 10th Dec 2018, 11:54 pm   #9
G3PIJpeter
Many thanks to all for the extra details and documents posted here. My GM4140 works after a fashion and gives a rough indication of the values of resistors and capacitors. I say rough because the EM4 indicator 'petals' do not narrow at one setting of the dial but rather across a range.
The next job will be to replace the internal capacitors and resistors as suggested. This bridge does seem to have had a variety of incarnations, with the Phillips version that I have perhaps earlier than the Mullard version - see http://frank.pocnet.net/instruments/...4140_flyer.pdf
- Peter G3PIJ
Old 11th Dec 2018, 12:16 am   #10
Refugee
Refugee's Avatar
I have got a GM4249 badged Phillips.
It is mainly an AC resistance unit but with an external standard it can do capacitance and chokes. Like most of these instruments the magic eye is still nice and bright.
It has recently begun to fall out of use because I have acquired a Marconi TF1313A.
Refugee is offline
Old 12th Dec 2018, 1:36 pm   #11
WME_bill
Default Re: Unknown R-C bridge [Mullard GM4140]
Unknown R-C Bridge GM4140
My posting #8 of 10thDec was getting a bit modern. My visit to the surprised Executive in Mullard Head Office was in 1951, not 1971. So the unit must be well before 1950, as I bought it second hand.
I have just switched it on again. The waxy capacitors have all gone, so replaced. They were 68 years old. And one dry joint. The resistors are old fashioned cracked carbon, and seem very stable. All the wiring is rubber covered with cotton waxed and still seems good. The standards seem fine.
I am always doubtful about this philosophy of removing every component for test and replacement. I suspect it can cause more failures later. A check on working voltages seems much the best way to identify problems.
Your problem sounds like a bad contact on the range switch. Check that you got the 2v AC across the two outer test terminals, and then across the ratio potentiometer and does the slider voltage vary.
wme_bill.
WME_bill is offline
