18th Jun 2014, 9:56 pm | #1 |
Can anyone reccomend a good 2M yagi?
Hi folks
After the debacle with my last new collinear I am hoping to avoid the same problem again by asking for your recommendations. The collinear I am using now is brilliant for vertical but I would like a horizontal option and am looking for a good quality and performance beam. Any suggestions? Thanks Peter |
19th Jun 2014, 1:16 am | #2 |
Re: Can anyone reccomend a good 2M yagi?
Buy or make your own? If the latter, then see
http://www.amateurradio.bz/2m_backpa...d_antenna.html and many other sites. - Peter |
19th Jun 2014, 11:15 am | #3 |
If you wish to build, I can recommend the designs here http://dk7zb.darc.de/start1.htm
Very effective and easy to build
I got food in ma belly and a license for ma telly My Blog - http://g7mrv.blogspot.com |
19th Jun 2014, 11:53 am | #4 |
Keep us posted what you go for Peter.
19th Jun 2014, 12:59 pm | #5 |
The moonbounce fraternity favoured long-boom Tonnas, then shifted to Cuedees
Have a search round their watering holes to see what's preferred just now. Look in Dubus for the latest home-build designs. David
19th Jun 2014, 5:59 pm | #6 |
Whatever became of the DL6WU long yagi? It was the thing (along with the Tonna) 30 years ago so is now nicely vintage. I built one for 70cms.
Even more vintage is my J-Beam six over six which I bought second hand in 1970 and which I hope to resurrect at some point. I homebrew extended it to become a ten over ten in the 1980s and bagged loads of DX with 3 watts from the TX - but I did have a good location... |
19th Jun 2014, 6:31 pm | #7 |
I have always found Tonna beams to be a good mix of price vs quality.
19th Jun 2014, 7:24 pm | #8 |
The Tonna i used back in England was excellent.
20th Jun 2014, 9:52 am | #9 |
Thanks for all your comments folks. I have built one or two in the past with varying degrees of success and I make my HF antennas including a rotatable dipole cut for 20M! which worked a treat, fed it with twin feeder and it would tune up on most bands, I have had much more success with HF ants than VHF.
I bought a DIY 8 element 2M beam kit some years ago which looked nicely made, it received fine but most DX stations could not hear me or at least with a considerably weaker signal than I was receiving, the collinear I am using now I am getting much better reports from so how an aerial can receive well and make such a poor job of transmitting I don't know. I don't need fantastically high gain, I just want something that will do the job, I had an 8 El J Beam XY for many years and that was excellent - until my tower came down and destroyed that and my HF3 tribander I could work into Holland on the J Beam but that is more due to my location than the aerial. There use to be quite a few secondhand aerials about but not so now it seems, most of the CB glut of G4s seem to have given up and all the equipment disposed of. I will let you know if and when I get sorted. Peter G0HET |
