7th Mar 2019, 11:12 pm | #1 |
Panel mount 2 pin male DIN plugs
Got a bit of a weird one here. I nabbed what appears ot be an early 1970s homebrew transverter last year at a hamfest for £1. Looks like it might be 6m. I will work out what it is later precisely. I was initially interested in eviscerating it for parts but it seems a shame to tear it up as it's quite well made.
However the power plug has a broken off pin. It appears to be a 2 pin DIN panel mounted plug which I have never seen before. I've only seen panel mounted sockets before. So in its default state, it would have two pins sticking out of it. Makes sense really as it's safer than having several amps of 12V on the lead end with two pins sticking out! Does anyone know if these existed or if it was a nifty hack. Also does anyone know here I can get one? I can find inline sockets, but not panel mounted plugs. |
7th Mar 2019, 11:26 pm | #2 |
Re: panel mount 2 pin male DIN plugs
A 2-pin din makes me only think of a speaker plug; one flat pin and one round?
B
Saturn V had 6 million pounds of fuel. It would take thirty thousand strong men to lift it an inch. Last edited by Bazz4CQJ; 7th Mar 2019 at 11:34 pm. |
7th Mar 2019, 11:30 pm | #3 |
That's the ones. Trying to find a panel mount plug.
7th Mar 2019, 11:37 pm | #4 |
Don't recall ever seeing such a thing; possible to take an end of line plug and fettle it
7th Mar 2019, 11:38 pm | #5 |
Yeah that's what I may be doing here. This one appears to be a genuine article though. Doesn't look hacked from what I can see. I was going to replace it with an RCA jack but the hole is too big.
7th Mar 2019, 11:51 pm | #6 |
Ok I took it to bits and there's suspicious looking glue in it. looks like this didn't exist and someone put a 2 pin speaker plug shell into a DIN panel mount housing!
7th Mar 2019, 11:52 pm | #7 |
Hello. Yes they certainly existed and I first encountered them on Hacker speakers for the Centurion stereo system back in the early 70's.
Here are a couple for sale. https://www.ebay.co.uk/itm/2-pin-DIN...sAAOSwsDZcMlND David. |
7th Mar 2019, 11:52 pm | #8 |
I can find the other end, 2 pin DIN female line cord https://vetco.net/products/2-pin-din-female-inline-jack, but the male end seems to be no longer available.
Option - make the hole bigger, fit a blanking plate with a suitable hole for the RCA or other type of connector? |
7th Mar 2019, 11:54 pm | #9 | |
I think the one I have here was hacked up though as it's sticking out of the panel flush with the surface. |
8th Mar 2019, 12:56 am | #10 |
They are not in any of my 1970's RS or Ambit catalogues, but are listed in the spring/summer 1971 KJ catalogue . Code 904 in the Audiopacks range, 15p.
8th Mar 2019, 11:29 am | #11 | |
Re: Panel mount 2 pin male DIN plugs
We didn't get the 50MHz allocation until 1986.
-- Graham. G3ZVT |
8th Mar 2019, 12:23 pm | #12 |
Possibly is. I'm going to reverse engineer it this weekend. It's showing short across rails at moment so I need to get to the bottom of that first. Once it's up I'll get a counter on it and see what it does. I can't read the crystal frequency as it's soldered down. Also the label which probably said what it was stuck down with tape which fell off a long time ago looking at the big square bit of residue.
It's probably scrap but someone put some time and effort into it so I figured it was worth a go at fixing it. To note it's a downconverter not transverter. It has no transmit chain. |
29th Jul 2019, 10:58 pm | #13 |
Back to this at last. It turns out I'm a prize idiot. This isn't a 2 pin DIN. It's a 2-pin Jones plug! I will chuck an opposite gender one in the next Mouser order I do. They still sell new ones for £3 a go.
As suggested by rambo1152, this looks like it was built for 4m. There is a "Jan 73" written in pencil on the side. It looks like the previous owner tried unsuccessfully to convert it to 6m and gave up based on the fact the crystal is, after hooking it out, a 16MHz one and date coded 1984 ((2x16)-18=50) whereas the rest is much older (1969 date code on the MOSFETs!). The short was some bad soldering in the end. The LO works but the multiplier doesn't because the tank coil is at the wrong frequency and the front end dual MOSFET, a 40673 is kaputt. There was no protection so it probably died of static. I may repair it yet and get it on 6m. It just needs a different capacitor and a new MOSFET. |
