6th Mar 2019, 11:49 am | #1 |
Blackened pins on NOS valves, any tips?
Anyone have any tricks for cleaning up the blackened pins on NOS valves? had a few and they take a worrying amount of effort to push into the rather tight sockets on far Eastern valve stuff. Coca cola or vinegar any good or is it too harsh?
6th Mar 2019, 11:58 am | #2 |
Re: Blackened pins on NOS valves, any tips?
T-Cut, Brasso or something similar will clean off any surface dirt.
6th Mar 2019, 12:47 pm | #3 |
I've used brasso on a cotton bud, seems to work.
6th Mar 2019, 12:48 pm | #4 |
Goddards Silver Dip (= non-abrasive):
https://www.amazon.co.uk/GODDARDS-Si.../dp/B005UXU4FS No connection with the supplier/online distributor, just a very satisfied user (1986: spent a happy couple of days cleaning up klystron cavities at Belmont with this stuff! ) |
6th Mar 2019, 1:39 pm | #5 |
I've come to rely on my fibre pen for this kind of thing. It's far better than I imagined, but it may be a bit of a faff for valve pins.
Andy G1HBE. |
6th Mar 2019, 1:41 pm | #6 |
6th Mar 2019, 2:08 pm | #7 |
Fibre glass brush works, the type used on pc boards.
6th Mar 2019, 8:27 pm | #8 |
Fibre glass brushing increases the surface area and therefore the amount and speed of new oxidisation.
6th Mar 2019, 8:53 pm | #9 |
I've used the PCB-cleaning fibreglass brushes, followed up by a suitable high-voltage-rated contact grease to prevent further oxidisation.. Electrolube CG80 seems to work just fine on the STC 5B/25x series of 807-alikes with 500V or so on the anode-pin.
6th Mar 2019, 8:59 pm | #10 |
Re Goddards Silver Dip, from their website, "Goddards Silver Dip is easy to use. Just dip, rinse and dry for a brilliant shine. Tarnish will dissolve away to bring out the natural beauty of your silver. Goddards Silver dip should never come in contact with stainless steel (my underlining). That stuff is only intended to be used on silver.
If the pins appear black, then that must be some kind of oxide, so it will only come off with either abrasion or chemical dissolution, but that may leave the pins very vulnerable to further and more rapid oxidation. What are the valves? I've ever only seen black pins on Acorn valves, which I think used an unusual copper/iron (?) alloy. B
8th Mar 2019, 7:20 am | #11 |
I cleaned up some valve base pins yesterday with a fibre pen then tinned them with solder, could you do likewise?
Andy.
8th Mar 2019, 8:49 am | #12 |
I've got an English Electric C178A/5894 ( Mullard equivalent QQV06-40A) with all it's pins blackened, I always assumed it was perhaps some silver oxide, a quick look on the web and unless it's the way they've been photographed quite a few of them also appear black, the one attached is from 'The National Valve Museum', website.
8th Mar 2019, 8:58 am | #13 |
Not sure I would go that far Andy?
Tinning them will make them even harder to insert into a 'tight' socket. And not sure there is any benefit? I assume that Bomber is talking glass button base (B9A / B7G) types as you seldom see octals blackened. Like others I use the fibre or brass jewellers pen first. I might resort to fine wire wool and Brasso for stubborn cases, but do it out side or well away from the equipment so as not to leave any wire strands near the sockets ... Alan
8th Mar 2019, 7:53 pm | #14 |
What about a small chunk of abrasive ink-rubber, suitably sized and with a hole that the pins will go in reasonably tightly? I think I may even have used fine emery-paper in the past, but I cringe a little at the thought now!
Colin. |
8th Mar 2019, 8:03 pm | #15 |
Those of us that are old enough will remember that valve pins back in the day, when new, were an almost black colour. Apart from the gold plated ‘special quality’ they were not shiny silver coloured metal like some of the newer specimens. Nothing with that, it was just the way it was.
8th Mar 2019, 8:38 pm | #16 |
I use fine emery paper, too abrasive?
John |
8th Mar 2019, 9:10 pm | #17 |
You could try putting the pins in lemon juice .Keep checking after say 10 mins so not to overdo
I haven't tried this on valves but works really well on battery terminals Cheers Pete |
8th Mar 2019, 9:41 pm | #18 |
Is there a danger that corrosive liquids could dissolve the metal pins where they pass through the glass envelope an let the vacuum out?
8th Mar 2019, 10:39 pm | #19 |
I use a suede brush....always have done. Suede brush to clean the pins and some contact cleaner sprayed on the pins afterwards (never in the valveholder). Never had any problems.
8th Mar 2019, 10:54 pm | #20 |
On novals and miniature valves I use a square of "Scotchbrite" pot scrubber, with the normal WD40/RP7 sprayed onto it. I push the pins into the scotchbrite and tilt/rotate the valve in the scrubber. I clean up with a clean rag or tissues. Works fine for me.
One does have to be careful with the white or yellow paint used for some valves identification, as the WD spray can dissolve some markings. Joe |
