Old 24th Feb 2019, 1:37 pm   #21
Paul_RK
Paul_RK's Avatar
Default Re: Dynatron RG 13 Ether Pathfinder
Originally Posted by Edward Huggins View Post
...but what make is that 12" Driver?
Hello Edward,
Another Goodmans. I wouldn't have recognised it either from the frame.
Paul
Paul_RK is online now
Old 24th Feb 2019, 4:15 pm   #22
Hartley118
Hartley118's Avatar
That's a nice array. The tweeter and mid-range look like Goodmans units, but what make is that 12" Driver?
The frame looks like that of the Jensen 12" speaker fitted to some 1950s Bell & Howell 16mm projectors, but the magnet is undoubtedly labelled Goodmans. Could it be a replacement unit?
Martin
BVWS Member
Hartley118 is offline
Old 24th Feb 2019, 7:16 pm   #23
John Caswell
Every one of the Dynatrons I have come across of that era fitted with the T10A tuner plus the stereo preamp and twin amplifiers (possibly LF10/15) were fitted with Garrard RC88 decks and a stereo PU cartridge but cannot remember the cartridge type sorry!
John
John Caswell is offline
Old 26th Feb 2019, 1:38 am   #24
dalgwcobl
I suggest that the stereo RG13, with a second speaker enclosure I've never seen before, may well be extremely rare. In those days, the top of the range models were pretty much made to order - and delivered direct from the factory - so the build was often bespoke. I agree that the changer was probably an RC88 but I can't remember what the stereo pickup was. It most probably was supplied with two plug-in heads; a mono LP/78 and stereo LP only. Of course, only the record reproduction was stereo.
dalgwcobl is offline
Old 26th Feb 2019, 4:01 am   #25
Synchrodyne
This Dynatron advertisement from Wireless World 1959 March provides a view of the chassis units that were available at the time, although not of the finished radiogram assemblies.
Name:	WW 195903 p.18,19 Dynatron.jpg
ID:	179042WW 195903 p.18,19 Dynatron.pdf
In that advertisement, the “Ether Pathfinder” name was applied only to the T10A AM-FM tuner. On the other hand, in the 1955 Radio Show Catalogue, the “Ether Pathfinder” name was applied to the suite of the then-new 10-suffix components.
Name:	Radio Show 1955 p.94,95 Dynatron.jpg
ID:	179045Radio Show 1955 p.94,95 Dynatron.pdf
As best I can determine, the T10A replaced the T10 for the 1958 model year. The main difference seems to have been that whereas the T10 used a “setmaker” type single-valve (ECC85) FM front end, the T10A had a two-valve FM front end (from the photographic evidence still a “bolt-on” unit) more aligned with typical hi-fi tuner practice. (The T11 was a tuner-control unit derivative of the T10A which evidently lost an IF stage, perhaps to leave enough room on the chassis for the AF valves.) Whilst the T10/T10A was not quite as elaborate on the AM side as Dynatron’s preceding AM-only tuner-control unit combinations, the T139 and T99, nevertheless with an RF and two IF stages and 4-position variable selectivity, it was certainly much better-specified than the majority.
The “small” amplifier, LF10/15/16 might have been derived from the Osram 912. The “big” amplifier, LF20, was basically a Mullard 5-20.
Cheers,
Synchrodyne is offline
Old 26th Feb 2019, 10:32 pm   #26
Ben9801
Thanks all, I think a Garrard RC88 4 would be ideal. Has anyone got one they may sell? Preferably with a stereo cartridge but that's not greatly important? Thank you.
Ben9801 is offline
Old 27th Feb 2019, 10:52 am   #27
Ted Kendall
In 1958 there wasn't much choice - Acos GP73, perhaps, or a Binofluid.
Ted Kendall is online now
Old 27th Feb 2019, 11:12 am   #28
Audio1950
Originally Posted by Ted Kendall View Post
[In 1958 there wasn't much choice - Acos GP73, perhaps, or a Binofluid.
A little too early for a Ronette BF40 Binofluid I think, but possibly there would have been two headshells, one with a Garrard GC2 for mono, and the other with a Garrard GCS10 or Acos GP73for stereo.
Audio1950 is online now
Old 25th Mar 2019, 6:18 am   #29
wannchev
My '57 Ether pathfinder has the Garrard RC88 turntable. The cartridge is a flip over Goldring 600.
wannchev is offline
