Old 5th Mar 2019, 9:40 pm   #1
Jolly 7
Default MW oscillator/ mixer using 2N3819 ?
Does an have a MW oscillator/ mixer circuit based on a 2N3819 that they'd like to share ?
Thanks.
Jolly 7 is offline
Old 5th Mar 2019, 11:53 pm   #2
MrBungle
MrBungle's Avatar
Default Re: MW oscillator/ mixer using 2N3819 ?
Relatively clever design here: http://kd1jv.qrpradio.com/swbcrx/AMSWBC.HTM
MrBungle is offline
Old 6th Mar 2019, 5:17 am   #3
Argus25
No Longer a Member
I think its reasonable to use a VCO IC as the L/O for a MW radio with a fine & coarse pot to control it, but that is if it is a sine wave oscillator. That circuit uses a square wave output from the 4046 into the mixer. A better IC choice would have been the MAX038 which has a sine wave output.
I have used the MAX038 as the frequency synthesizer in a device for testing and aligning transistor radios, I have posted it before. But the circuit could be lifted out to make a L/O for a MW radio, the sub-circuit is on page 16:
http://worldphaco.com/uploads/The__H...nsanalyser.pdf
Argus25 is offline
Old 6th Mar 2019, 12:45 pm   #4
MrBungle
MrBungle's Avatar
Yeah it's not perfect and might end up with a few birdies from harmonic mixing products but it's cheap and easy! I reckon you can possibly work around that with a few minutes in excel playing with the IF and LO frequencies.
MrBungle is offline
