20th Dec 2010, 10:47 am | #1 |
GEX34 diode?
Anyone know what the equivalent would be from Mullard?
I assume this is a GEC component. |
20th Dec 2010, 11:18 am | #2 |
Re: GEX34 diode?
OA90(50V) or 91(115V) depending on Voltage required
20th Dec 2010, 11:23 am | #3 |
Re: GEX34 diode?
My 1968 Mullard data book gives the GEX34 equivalent as the AA119 germanium point contact diode, for simple radio circuits most other germanium diodes would probably work fine, 0A81, 0A91 etc.
Regards, Mick. |
20th Dec 2010, 11:42 am | #4 |
Re: GEX34 diode?
Or a B_E B_C junction of a germanium transistor.
20th Dec 2010, 8:54 pm | #5 |
Re: GEX34 diode?
I bought a bunch of 'surplus' diodes, but they have the Service CV7130 reference code.
Has anyone got a guide to it? I was told they were one of the types (OA81, 90 or 91), but I can't remember which. The component itself is marked with the same CV7130. What inverse voltage was the GEX34 rated at? |
20th Dec 2010, 9:08 pm | #6 |
Re: GEX34 diode?
I think a GEX34 is 50V ..............Daten/electr.data: I F: 1 mA; U F: 1 V; I sp: 250 µA; U sp: 50 V; Imax: 30 mA; Umax: 60 V; tmax: __ °C.
CV7130 is a OA91 Last edited by oldticktock; 20th Dec 2010 at 9:13 pm. |
21st Dec 2010, 8:12 am | #7 |
Re: GEX34 diode?
CV7130 = OA91, brilliant equivalent.
16th Feb 2011, 7:39 am | #8 | |
Re: GEX34 diode?
I was after the data on the GEX34 myself because it is used as the detector diode MR1 at the ouput of the meter amplifier of the AVO Transistor Analyser Mk 2 which I am restoring. http://www.radiomuseum.org/schemavie..._mk2_sch3b.pdf (right hand side VT3, 4, 5)) Incidentally, this amplifier looks ideal for translation to silicon transistors in place of the Ge OC75's and CV2400 without too many problems. A readjustment to the values of the base biasing resistors should be all that is required. The collector dc rail is nominally -8.2V and in all 3 transistor stages the resistors are 120k (upper) and 10k (lower) and the Ge transistors have an Hfe of approx 100. My thinking was to change the bias resistors to 180K (upper) and 27K (lower) and use a BC178 (Hfe typ 180) as the replacement for all 3 Ge transistors. I would appreciate any input from others as to their thoughts on whether this seems a reasonable modification. |
16th Feb 2011, 10:48 am | #9 |
Re: GEX34 diode?
I wonder if the GEX34, is equivalent to the 1N34, the data for which is:
Piv 60v max. Reverse current: 30ua at 10v, max forward volt drop 1 at 5ma If so, new 1N34s are widely available. EG, an ebay supplier is currently offering packs of ten for £5.15 inc P&P. I'd rather not post the link, but google 'ebay+1N34' will throw up several sources. The 1N34 is a germanium dode, specifically for signal detection - not a rectifier diode. Note: It's number 1 not letter I. ('one en' not 'eye en'!) (The topic of GEX34/1N34 has been debated in another radio forum). Hope that helps a bit. David. |
16th Feb 2011, 12:53 pm | #10 |
Re: GEX34 diode?
PM me if you want a GEX34
Jim |
16th Feb 2011, 1:25 pm | #11 | |
Re: GEX34 diode?
16th Feb 2011, 3:21 pm | #12 |
Re: GEX34 diode?
Hello
I am not sure what application you wish to use the GEX34 or OA91 diodes. They are both Germanium point contact diodes and are suitable for use as AM detectors and have a very low junction capacitance of around 0.9pF at 45MHz. I have scanned the GEC data on the GEX34 and the Mullard data on the OA91 diodes. Please find attached PDF’s for the diodes. I hope this information is of some help. Regards Stan.
Junk accumulates to fill the space available. |
19th Feb 2011, 9:14 am | #13 | ||
Re: GEX34 diode?
