22nd Mar 2020, 4:54 pm | #1 |
My isolating transformer unit
Some years ago I was given an RS 200VA isolating transformer. The primary is tapped 0-230-415V, there are 2 secondaries each 55-0-55V.
Today I decided to finally get round to putting it in a box and wiring it up with suitable connectors. Mains input on an 'IEC' chassis plug (you know what I mean), 1A thermal circuit breaker (I've seen similar breakers, high rating used in 'site transformers' and so far this one has not nuisance-tripped) and a double pole toggle switch (rated for 3A inductive load, so it should be OK). On the output side, a 4 pole changeover switch. Two poles connect the secondaries in series (220V out) or parallel (110V out), actually nearer 230 and 115V due to the high-ish mains voltage here. The other 2 poles connect the output to either an 'IEC' socket (230V) or a US mains socket (115V). I've connected a neon indicator across each one to indicate which is live. I could only find a pair of 110V neons in the junk box. No problem, the neon bulb is the same in the 230V version, just a larger series resistor. So a 180k resistor in series with the unit made the 110V one fine on the 230V output. The reason for the 2 different output connectors is that to over-voltage an American device I both have to mis-set the toggle switch and plug it into the wrong socket (which would mean finding an adapter lead etc). I think that's unlikely to occur. And now for that old chestnut of output side earthing. Obviously the secondaries are fully floating wrt earth. What I did about the 'earth' pin on the output sockets was wire them together (only one socket will be used at a time after all) and to a 4mm socket on the case. Another 4mm socket (spaced the standard 3/4" away) is linked to mains earth/the casing. So I can jumper them toghether if I want the safety earth on the output linked to mains earth (and I can see times when it is a good idea) or not as I choose. Or put a flying lead into the 'mains earth' 4mm socket to connect to the exposed metalwork of the unit under test. Maybe not ideal for use by non-technical people but I think it will be fine on my workbench. |
25th Mar 2020, 6:59 am | #2 |
Re: My isolating transformer unit
I've attached a couple of photos of the thing (the complete unit and the wiring on the back of the panel) along with the circuit diagram just in case anyone is interested.
25th Mar 2020, 7:38 am | #3 |
Nice one Tony, where did you get the case from? Been looking for something suitable for a 250va transformer I have.
25th Mar 2020, 7:58 am | #4 |
Grand work Tony, neat work. I have an iso tfmr case Keith if you want it, it's in a different style to that one though.
Andy.
25th Mar 2020, 9:10 am | #5 |
Nice work Tony very neat I also have a 250va transformer that needs a case .
25th Mar 2020, 11:04 am | #6 |
The case was originally from RS, but I don't think they still do them. I've had it for years, it came in a load of 'junk' (useful components) that I was given. RS do still sell plenty of cases that would have done of course.
The case came as a flat pack and was supposed to clip together with the front and back panels held on with screws into caged nuts. But I drilled through the flanges and put nuts and bolts in as well, I didn't trust the clip part. |
25th Mar 2020, 2:44 pm | #7 |
that is a nice looking case and design. I wish my metalworking / design skills were as good as yours.....
Regards Peter B |
25th Mar 2020, 6:05 pm | #8 |
Most of the metalwork was done by hand (marked it out, centre-punched, drilled). But I did use my limited milling facilities (a vertical slide on the lathe) to make the rectangular holes for the 3 connectors.
Not much design IMHO. Once I'd got the transformer it was just a matter of connecting the input to the mains and doing something with the secondaries. Series/parallel switching (to give suitable voltages for US or European/UK equipment) seemed an obvious idea. When the current situation has settled down and I can go and get components again I'll get a couple of stud-mounted 4mm plugs and make a shorting link (metal block with 2 tapped holes to take said studs) for the earth sockets. |
25th Mar 2020, 8:15 pm | #9 |
Nice work, Tony!
I love those old RS cases... wish they were still made!
Al |
25th Mar 2020, 11:30 pm | #10 |
Now there's a coincidence, I used the same case for my isolating transformer.
Instrument case Type 1 from 1973 RS catalogue £4.00 each. Long gone I'm afraid especially at that price. Jim |
26th Mar 2020, 12:54 pm | #11 | |
Something for £50 today would be about the same price in real terms.
27th Mar 2020, 10:32 am | #12 | |
Keith |
