Old 20th May 2021, 2:22 pm   #1
Nanozeugma
Nanozeugma's Avatar
Location: London, UK. Bury, Lancashire quite regularly :)
Default Vintage Electrolux Microwave.
Afternoon
Many years ago, I bought a first generation (650W) microwave oven.
Its an Electrolux (made in USA) model 56-0 884-10 - strange model number, I know.
It has a very large cooking cavity, a 1KW browning element and a plug in temperature probe.
It's still in regular use.
The other day the internal lamp which illuminates the cavity went o/c (40W MES) and having sourced a replacement, I was obliged to remove the cabinet in order to replace it.
On doing so, I discovered that the belt that drives the stirrer fan in the "roof" had disintegrated (it does not have a rotating turntable.)
This is, of course, an appliance specific part (unlike the bulb) and sourcing a substitute is proving a problem.
Googling the model number produces no hits whatsoever, even an image search produces nothing even similar.
So, I'm a bit screwed (!)
It's brown with a wood effect metal case and has a touch keypad and a green display.
Anyone ever heard of this model?
Thermionic Emission, warms the cockles of your tubes.
Nanozeugma is offline
Old 20th May 2021, 2:29 pm   #2
Station X
Station X's Avatar
Default Re: Vintage Electrolux Microwave.
What form of belt is it? Generic belts are available on eBay or you can make your own using 'O' Ring cord.
Graham. Forum Moderator
Station X is online now
Old 20th May 2021, 7:59 pm   #3
mark_in_manc
Yes - that green round-section belting which you join with a hot knife, is really good stuff and the joint is very strong indeed. I have bought several lengths of different cross section from ebay - but only useful if you can use a round-section belt.
"The best dBs, come in 3s" - Woody Brown
mark_in_manc is offline
Old 20th May 2021, 9:49 pm   #4
emeritus
Another vote for hot melt polyurethane cord. I bought a range of diameters some years ago from RS and it has been very useful, not only for drive belts, but for O ring seals. The RS stuff was available in both smooth and rough, and in red and green. I found the barrel of my Henley Solon ideal for melting it.
emeritus is offline
Old 24th May 2021, 9:50 am   #5
Nanozeugma
Nanozeugma's Avatar
Thanks for the suggestions. Any idea where one might obtain a modest quantity of said hot melt polyurethane cord? All I've come up with thus far is a Chinese based seller on Ebay offering min 2mm diam min length 1m.
Using RS would be prohibitive (can't find reference to same in any event.)
All / any contributions most gratefully received
