Reply
Old 18th Sep 2011, 6:08 pm   #701
dseymo1
Default Re: AVO Multimeter survey
Model 47A (Admiralty version), serial 13450-144 now offered below for spares - sadly badly water damaged, but another one for the record
dseymo1 is offline   Reply With Quote
Old 20th Sep 2011, 4:05 pm   #702
Paul Adams
Sent you a P.M.
Paul.
Paul Adams is offline   Reply With Quote
Old 22nd Sep 2011, 9:10 am   #703
noble kiwi
Two model 40 from down under. 6164-B1051 and 180-B-461.F. They are different in several detailed respects.
Trevor.
noble kiwi is offline   Reply With Quote
Old 25th Sep 2011, 1:10 pm   #704
Paul Adams
Two more: 54292-84/971 (model 8 mk 4)
20908-945 (AD Patt 47A) complete with original battery.
Old 30th Sep 2011, 2:26 pm   #705
phasedout
No 32, Avo Universal meter, i have approx 50, this one has Serial No 10945-36, 10 volt and low ohms scales marked in red, works great....regards....Alan.
phasedout is offline   Reply With Quote
Old 30th Sep 2011, 9:27 pm   #706
pmmunro
Antony,
Is the battery for your 47A the original type or the actual original supplied with the meter when new? A photograph would be interesting in either case.
Alan,
Does No 32 mean the 32nd meter in your collection and is it a Universal Avominor? If it is a Universal Avominor the serial number could possibly indicate a meter made in 1936 but I am a bit short of serial numbers from this period to establish a pattern.
Again a photograph would be interesting, especially if you can get a well focused image of the scaleplate.
PMM.
pmmunro is offline   Reply With Quote
Old 1st Oct 2011, 7:34 pm   #707
Paul Adams
Hi PMM,
Not sure about the Battery as the date on it say's 19th July 1973, anyway here's a picture of the said beast !
Paul.
Old 2nd Oct 2011, 1:39 pm   #708
phasedout
Hi Pmm, the date i suspect is 1936, its like a mini Avo shop here, i have 50 Avos in my collection, i am having problems with uploading pics but soon as its resolved i will post a picture of this meter, which is a Universal AvoMeter...regards....Alan.
Old 10th Oct 2011, 9:39 am   #709
scopedon
Hi My AVO is a model 8 Mk111. Serial No 17066.S65. I have been using it for 30years+. Still going strong, I mean the AVO not me. Regards scopedon
scopedon is offline   Reply With Quote
Old 10th Oct 2011, 2:44 pm   #710
Phil G4SPZ
Phil G4SPZ's Avatar
My latest AVO acquisition is a Model 7, 71047-A40931 which I interpret to be a relatively late meter of this type, made in October 1947? £4.99 from eBay.
Phil
Phil G4SPZ is offline   Reply With Quote
Old 10th Oct 2011, 6:09 pm   #711
pmmunro
Scopedon,
Could that serial number be 17066.565? There would not normally be an 'S' in that position.
Phil,
Thanks for the information; your serial number is consistent with October 1947. Do you know if your meter has a block magnet movement or the earlier type with a horseshoe magnet? The design changed just about his time.
PMM.
Old 11th Oct 2011, 9:55 pm   #712
Dekatron's Avatar
AVO 7 bought just a few days ago in original cardboard box still wrapped in a plastic bag which has been taped with some old tape that now has gone brownish.
The manual is still in the bag with the meter and all looks pristine, including the leads and clips, but the box has been torn open quite roughly by the seller - but I got the box too and it has a label on the outside with the same serial number as the meter, which is: 02226 7/11/77.
It might not be as old as some think, but it is just what I needed!
The meter movement is very nicely dampened and there are no corrosion or damages that I can see through the plastic bag.
I just hope these instruments were shipped without natteries in the battery compartment!
How much did I pay then? GBP £30!! Quite a bargain!
ID:	57258   Click image for larger version
ID:	57259   Click image for larger version
ID:	57260   Click image for larger version
ID:	57261   Click image for larger version
Martin, Sweden
Last edited by Dekatron; 11th Oct 2011 at 10:00 pm. Reason: Added pictures - which I forgot....
Dekatron is offline   Reply With Quote
Old 11th Oct 2011, 10:43 pm   #713
peter.sables
peter.sables's Avatar
Hi
My trusty AVO is a 8V / 5 / 76 No. 05216
Pete
peter.sables is offline   Reply With Quote
Old 12th Oct 2011, 8:08 am   #714
greenstar
greenstar's Avatar
Model 8X MkIII (Panclimatic),
serial number appears partly defaced, reads 6625-99-943-15xx.
Acquired by myself from Mountain Breeze Ltd, via their engineer, when bought out, about 1990.
Tony
greenstar is offline   Reply With Quote
Old 12th Oct 2011, 12:37 pm   #715
pmmunro
Tony,
That is a NATO Stock number, not the serial number. The serial number should be on the scaleplate of a Model 8 Mark III. On many military meters it is on the lower left edge, rather than the right hand side as on the commercial models.
It will be of the form XXXXX-mmyy where m is the month and y the year of manufacture.
PMM.
Old 12th Oct 2011, 4:50 pm   #716
greenstar
greenstar's Avatar
Ahh, yes, on the scale it says: Model 8 No. 47532-10,66.
Wondered about that.
Tony
Old 13th Oct 2011, 4:15 am   #717
Technomaniac
Hi, All. Anyone passing up an AVO in a second hand shop should think twice. Maybe she'd swap it for something you have. Check out Farnell or RadioSpares online prices for the current ones, assuming they still have them, not long ago they were SURPRISINGLY expensive.
My first AVO was bought new for $110 AU when I was an apprentice, c.1966, it's an 8 MkIII Ser 16574.565 also have 8 MkIII 33977.166 and a Test Set Multirange No.1 High Sensitivity 6625-99-105-7050 1134.167.
I have at least one more Model 8, and at least two solid state ones which came from the tip, hiding somewhere, an in-circuit transistor tester (hand held) which I bought new also when an apprentice. Anyone who wants to donate me an AVO valve tester, I'm sure I'd find room for it somewhere. I had a bent one from the tip but an apprentice talked me into selling it to him cheap. Regretted it ever since, particularly as he left in a hurry at the end of his time. The Multirange No.1 mentioned above is a metal-clad similar to the Model 8, and has a higher high voltage range - Military. Also I think I have a model 9 from the tip somewhere. (Can't find ANYTHING since the February Floods - didn't get drowned, but new concrete slab behind blocked the normal drainage path and had a foot of water through the place.) I also have a 50A shunt for a Model 8 which cost nearly as much as the new meter.
Cheers,
Technomaniac.
Technomaniac is offline   Reply With Quote
Old 13th Oct 2011, 1:37 pm   #718
pmmunro
Technomatic,
From what you write it seems possible that you haven't heard that Avometer (Model 8 Mark 7) production ended nearly two years ago. The reason given was that the jewelled pivots, which came from Switzerland, were no longer available.
At the end of production, the cost in the UK was around £900 and it had been rising much faster than general inflation for some time. The movement of the Mark 6 & 7 was very similar to the Mark V but the last two variants used rigid pcbs with wire interconnection and eliminated the flexible printed circuits of the Mark V. These changes must have significantly reduced the cost of production.
I understand that AVO (Megger) is now owned by an American company and I suspect that they decided that the Avometer was too old a concept for their product image.
PMM.
Old 13th Oct 2011, 7:24 pm   #719
Philips210
Hi.
My Model 8 Mk3 has the serial number 105117 and dated October 1969 (1069).
I also have a Model 7 (Panclimatic), serial number 95938-A dated February 1965 (265)
Regards
Symon.
Philips210 is offline   Reply With Quote
Old 15th Oct 2011, 10:07 pm   #720
Phil G4SPZ
Phil G4SPZ's Avatar
Originally Posted by pmmunro View Post
Phil,
Peter,
Thank you for that. I think this meter has never been opened, and as it seems to work on all ranges and the battery compartment is pristine with no corrosion (the first instrument in such condition that I've managed to obtain from said source), with all due respect I'd prefer not to open it up to find out.
Is it possible to ascertain the magnet type from a detailed visual external inspection?
Phil
Phil
Reply
