Old 29th Nov 2023, 1:13 am   #1
Sparky67
Sparky67's Avatar
Default Motorola Mc Micro Ident
Hi all,
A family member kindly gave me what I think is a Moto Mc Micro and its Moto PSU which he apparently found in a skip. I am now trying to identify what it is exactly, freq band, power output, conventional or trunker, to see if it’s reusable.
The model number is MAU33YEA5G22AK and type number is 33YEA. Are there any Moto experts out there who can decode that for me please?
The PSU has its earth pin missing and tin foil in place of the mains fuse!
Martin
G4NCE
Sparky67 is offline
Old 29th Nov 2023, 12:25 pm   #2
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: Motorola Mc Micro Ident
Have you tried here?
http://www.batlabs.com/micro.html
Rather afraid that what you have is a BandIII trunking set. Some good spares but probably not going to be useful. Different processor and audio to the more ordinary PMR versions.
Jon_G4MDC is offline
Old 29th Nov 2023, 1:02 pm   #3
Sparky67
Sparky67's Avatar
I have Jon but it doesn’t seem to tie up with the info on that site. I suspect it’s trunked and in band 3 as well, but would like positive identification before it goes in another skip.
Cheers,
Martin
Sparky67 is offline
Old 29th Nov 2023, 6:32 pm   #4
Mascot-22
The odd bit of the model number is the YEA , not come across that before apart from that it's a Hi band 12.5khz ,25watt unit. If its trunked there is normally a eeprom glued into the control board, What type of control head is fitted
Paul
Mascot-22 is offline
Old 29th Nov 2023, 10:06 pm   #5
Sparky67
Sparky67's Avatar
Here are the boards and the front panel if it helps with an ID?
Martin
ID:	288991   Click image for larger version
Sparky67 is offline
Old 30th Nov 2023, 10:54 am   #6
Jon_G4MDC
Jon_G4MDC's Avatar
With that fat processor and EPROM it's a Band III trunking one for certain.
You might be able to modify the RF boards to some more useful frequency range but I have never heard of anyone making use of that control board. Front panel is of course useful.
I have a 6m one modified from Low Band. It was my regular drive time set in the early 2000s. It replaced a Pye MX295 which was my earlier 6m FM set. That was originally Band III as well and quite useless except it had varicap front end tuning which is helpful to cover all of 6m. Luckily the trunking board on a '295 can be removed easily if you revert to an ordinary channel switch.
Old 30th Nov 2023, 8:09 pm   #7
Mascot-22
Martin
I have had a dig in the shed and found a similar mc micro as the unit you have.
Looking at the photo of your control board it is Not a MPT1327 board but looks to be hybrid motorola trunk system mk 1or 2 which didn't have a lot in common with MPT1327. There was a system that operated in the west midlands up to the late 1990's as a single site system and used 162 & 157 mhz frequencys. You can get the radio into service mode by shorting the 2 test pads on the RH side to cpu chip at the same time as pressing the ptt and turning the radio on. If nothing else there are some useful bits to be salvaged.
Old 30th Nov 2023, 11:35 pm   #8
Sparky67
Sparky67's Avatar
Thanks Paul,
The ‘on’ display is what I see as well so looks like it’s probably from the same system. Is this of any use to you before it goes? Drop me a pm or text over the weekend if you would like it.
Cheers,
Martin
Sparky67 is offline
Old 1st Dec 2023, 10:00 pm   #9
Sparky67
Sparky67's Avatar
Mods - the radio has now been fully identified as being off a proprietary hi-band Motorola trunked radio system which was installed in the West Midlands so the thread can be closed. Thanks.
Sparky67 is offline
