13th Jan 2022, 4:11 pm | #1 |
Ex-army antenna mast info needed.
I have bought an ex army six section telescopic antenna mast for my forthcoming radio shack. Goes up around 30 feet or so. It is air powered and I have a compressor here, but no information on what air pressure psi I need to raise the thing. Obviously I don't want to put too much air in it, as I can visualise the top section parting from the rest of the mast like a space rocket and ending up in someone's greenhouse!!
It is the sort of mast that the army used in their radio trucks I believe but I can't find any info on the net as yet. I also believe there should be a restrictor valve of some kind, for the air pressure, so that it would be impossible to over-inflate. Mike |
13th Jan 2022, 4:57 pm | #2 |
Re: ex-army antenna mast info needed
In pneumatic cyclinders, a flow restrictor is used to govern the speed, and a pressure regulator governs the force. Doesn't your compressor have an adjustable regulator? Set it low and crack open the outlet valve and see what happens.
Kevin |
13th Jan 2022, 5:05 pm | #3 |
Clark Masts are the military favorite, here https://www.clarkmasts.com/mast-acce.../2/ab-control/ 25psi I would go for just enough to raise it and load plus 10%.
13th Jan 2022, 5:32 pm | #4 |
Re: Ex-army antenna mast info needed.
Hello Mike how about nipping down to the local army barracks and ask to speak to the Signals/ REME workshop more senior staff. I have a compressor and like Kevin says, about the regulator I can adjust the pressure on mine. So, how about starting very low PSI (or it's Bars now) and see how things go. If you are a member of RSGB I'm sure a posting in Radcom you will soon get a positive reply if not here. Ted
13th Jan 2022, 5:45 pm | #5 |
Hi Mike
As a crude calculation, if the cylinder diameter is 3 inches and the pressure is 25 PSI that would support 178 lb (80 kg) The type I used to be involved with had a locking knob for each section, so raising it was a fairly controlled process of progressive unlocking and locking, starting with the top section. Once it's up and locked off you don't need any pressure. Surprised you don't have a data plate, unless it's been removed or painted over. |
13th Jan 2022, 6:00 pm | #6 |
The pneumatic masts I remember using back in the 70s and 80s when with the Territorial army were Clark "SCAM" [Self Contained Antenna Mast].
See here: http://www.portablemasts.com.au/Clark/clarkp17.htm for lots of useful info!
13th Jan 2022, 11:29 pm | #7 |
Clark's masts were used extensively by the Royal Observer Corps underground posts. They used a hand pump and the pressure was therefore relatively low.
It should be noted that only silicon grease should be used when lubricating these. Chris R |
14th Jan 2022, 1:24 am | #8 |
I spoke to the technical support at Clark Masts who say to use any engine oil for scam 12 mast lubrication.
14th Jan 2022, 10:05 am | #9 |
I have a spray gun regulator that I can try. The mast looks very similar to the one pictured in the last link without the stand and the other extra items. I was thinking around 15 psi, so will take it easily.
Mike. |
14th Jan 2022, 3:09 pm | #10 |
I should have said that I was referring to the 30' masts. The Clark maintenance instructions definitely said silicone grease. Interesting to note that they use engine oil on Scam masts. Perhaps they have changed the formulation of the seals.
We carried a good stock of the 30' seals. Some of the 'customers' thought that they were being helpful by doing DIY servicing and used normal grease. This resulted in the seals swelling and jamming the mast. Units were always stored vertically, to avoid the distortion of the seals when laid on their sides. Masts installed on vehicles did use a 12v compressor - it took an age to pump them up. The larger trailer masts were taken to Clark's for service. They also had an on board compressor. One interesting occurrence happened when a 100' version was left extended for a long period. Trying to get it to come down again proved to be difficult. Chris R |
