Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 11th Apr 2018, 6:49 pm   #1
line sync
Default Did the forum just go down ?
I typed up a PM to send to a member , pressed send and the forum went off.
Was my laptop playing up or did the forum go down ?
Robin
line sync is offline
Old 11th Apr 2018, 7:21 pm   #2
ms660
ms660's Avatar
Default Re: Did the forum just go down ?
Went off down here too, since returning the back button doesn't work and the definition/resolution looks slightly different.
Lawrence.
ms660 is offline
Old 11th Apr 2018, 7:22 pm   #3
paulsherwin
paulsherwin's Avatar
I think there was a glitch about half an hour ago. I have no access to the server logs so can't confirm a definite problem, but I certainly got a few timeouts around then. Everything seems back to normal now.
paulsherwin is offline
Old 11th Apr 2018, 10:01 pm   #4
Paul Stenning
Administrator
Paul Stenning's Avatar
I have just sent an email to the hosting company to ask if there were any issues around 6:45pm this evening. I will update when I hear back.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is offline
Old 11th Apr 2018, 10:45 pm   #5
Paul Stenning
Administrator
Reply:
We had a network routing outage due to an issue at an upstream provider.
They had a peering router blip which caused routes to be dropped and reconvergence as things settled down.
It should only have been 10-15 minutes of intermittent reachability and/or higher-than-normal packet loss.
Please let us know if you see any further issues though.
At least this confirms it wasn't your computers or internet connections.
Paul Stenning
