Old 22nd May 2019, 7:47 pm   #1
John10b
Default Output transformer on Blackbox
I’m doing a bit of background reading in preparation for restoring a Pye Backbox.
I keep coming across reference to the output transformer being “fragile “ and problematic. Could you tell me why this should be? Many thanks.
John10b is online now
Old 22nd May 2019, 8:11 pm   #2
Sideband
Sideband's Avatar
Default Re: Output transformer on Blackbox
Maybe they were borderline rating. As the amplifier ages and the coupling capacitors start to leak, the output valves get stressed and draw more current. After a while the transformer will just fail on the primary winding.
Sideband is offline
Old 22nd May 2019, 8:31 pm   #3
I'd be more minded to think of classic "green spot" corrosion rotting through the windings.
If the OPT does fail, don't worry: you can easily/cheaply get a replacement transformer [with much-better insulation] from the likes of Hammond.
Alternatively, a 12-0-12v mains-transformer rated at 10W or so will work. So it's not "HiFi" rated but unless you've got traceably certified, historically-burned-in Golden Ears™ you won't notice the difference.
Old 22nd May 2019, 8:56 pm   #4
Ed_Dinning
Hi Gents, there were several different transformers used on the BB.
The early units using the EL42 were simply PP, later units were UL PP.
The later units were UL PP and used the PCL83.
They were all pitch covered to keep out moisture and I have not seen many with "green spot". The majority of them have died from excessive current caused by leaky caps; but, the feedback system (3 different loops) on the PCL83 types has been known to oscillate ultrasonically and cause the valves to draw high currents.
The anode winding on all these units were a bit marginal and subject to getting hot
Note that one of the units had a mains transformer with an unused 60v winding.
Ed
Ed_Dinning is online now
Old 23rd May 2019, 10:56 am   #5
Sideband
Sideband's Avatar
Yes that's a good point about HF oscillation....I've had that on the PCL83 version. Fortunately the transformer survived.
Sideband is offline
Old 23rd May 2019, 2:03 pm   #6
John10b
Thank you all for your informative replies. I already had you in mind Ed if the transformer turns out to be faulty, but I’m jumping the gun, I won’t have the BB for a week or so, if the transformer is faulty I’ll consider my options.
Old 30th Jun 2019, 7:56 pm   #7
John10b
Just an update. Fortunately the output transformer was ok, so far, so this thread can be closed.
