Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#1 |
Hi
I wonder if anyone has Lemco dogbone capacitors, 3000pF (Hi-K series, 500 or 750V) like the one in the photo. I'm looking for 10 more of these for an RF section. Many thanks Helder |
#2 |
Hi Helder,
I have some 3nf tubular capacitors that are similar to your Lemco one. These are light brown in colour and measure approx 17mm long x 4.5mm dia, they don't have any voltage stated on them. Having tested a couple they measure 2583pf and 2658pf which if at 20% tolerance are a bit low but still in tolerance. I can send you 20 of them for cost of post, PM me if it is of help. Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battleship Galactica) |
#3 |
Hi Helder,
I may have some, let me check, although I get the feeling they are 1000pf. I'm looking for some at 500pf in the same style, but they do seem quite difficult to pin down. Sean. |
#4 |
Think these were also sold by Radiospares back in time so might find them with the RS logo on.
#5 | |
![]() Quote:
Helder |
#6 | |
![]() Quote:
I checked my small stock of these, but unfortunately I don't have any 500pF. I have 1x1500pF, 2x2000pF (one of them RS marked) and 3x1000pF, in case you're interested. Helder |
#7 |
#8 | ||
![]() Quote:
Thank you for looking, very kind. This particular project will also allow me to use the Lemco/RS 500pf Mica rectangles, but even so these are still hard to find. Sean. |
#9 |
Better known as tubular ceramics. They've stood the test of time quite well.
There were 'High-k' ones in the 1000pF region, as well as low tempco ones in the 1-100pF region. David
#10 | |
![]() Quote:
Helder |
#11 |
On the other hand, the High-K ones have a rather large positive temperature coefficient, and their capacity increases by 10-20% for a temperature change of only a few degrees. So perhaps they were designed for an operating temperature slightly above room temp. Just guessing here.
Helder |
#12 |
I got a great set of 3000pF capacitors from Dave today, so this thread can be closed.
Many thanks, Helder |
