Old 3rd Jun 2020, 12:16 pm   #21
rockinmark
Default Re: Ekco U199
Hi Graham the volume is at a volume you can listen to but it's set to full turn it down a bit then you cant hear it what one is the reservoir cap using chassis as -
rockinmark is offline
Old 3rd Jun 2020, 12:43 pm   #22
Station X
Station X's Avatar
C26 Trader sheet. Just check the voltage on both the caps in the can.
Graham. Forum Moderator
Station X is online now
Old 3rd Jun 2020, 2:04 pm   #23
Glowing Bits!
Glowing Bits!'s Avatar
Originally Posted by 60 oldjohn View Post
I think there may be a mistake on the circuit diagram, The scale lamp 110-120v ?
John.
That is a mistake, it should be a mains 240v bayonet pygmy bulb, the diagram may possibly be for the American market.
Rick, the annoying object roaming the forum.
Glowing Bits! is offline
Old 3rd Jun 2020, 2:33 pm   #24
ms660
ms660's Avatar
John.
It's not a mistake, the 110-120v doesn't relate to the bulb, it relates to the low voltage tapping as can be seen by the indication line.
Lawrence.
ms660 is offline
Old 3rd Jun 2020, 6:34 pm   #25
rockinmark
After rechecking the resistors R19 4.7k resistor was a long out replaced that and now it is loud but when you turn volume up it goes distorted but the sound is much better than before
Old 3rd Jun 2020, 11:14 pm   #26
peter_sol
Have you replaced the tubular wax capacitors especially the output valve coupling cap?
peter_sol is offline
