Old 4th May 2020, 5:42 pm   #61
Paulus.d
Default Re: Lockdown project - Sony TC-200
Hi guys , been to work today so just got back to it....Thanks for the circuit drawings ...that really helps loads.
Paul
Paulus.d is offline
Old 4th May 2020, 5:59 pm   #62
Paulus.d
Originally Posted by ms660 View Post
Next, in playback with the fault condition present check the voltages on V101 and X101...
V101 anode (pin 6) screen grid (pin 8) control grid with volume control turned up (pin 9) and cathode (pin 3)
X101 collector (junction of R105 & C104) base (junction of R104 & R103) and the emitter (junction of R107 & the +ve of C103)
Also determine whether the pre-amp transistor (X101) circuit is the early type (germanium transistor) or the later type (silicon transistor) as the expected voltages are different.
Can we assume that the Rec/Pback switch contacts are clean and making contact and that the tape path's ok?
When measuring the base and emitter voltages you need to know to at least one place after the decimal point on the meter, eg: if say on a higher range the meter says 7 volts but on a lower range it says 7.12 volts it's the lower range meter reading that's of interest.
Lawrence.
Right , I have possibly mixed up X201 for X101 .... so the OC140 is X101...
The readings are ....
Collector ...8.5v
Base ...8.8v
emiter..9.3v
Paul
Paulus.d is offline
Old 4th May 2020, 6:04 pm   #63
Paulus.d
JUst for my own information I compared x201 with x101
collector 9.6v
base 13.8v
Emiter 9.6
The bases are different..
Paul
Paulus.d is offline
Old 4th May 2020, 6:29 pm   #64
ms660
ms660's Avatar
Collector ...8.5v
Base ...8.8v
emiter..9.3v
Paul
The transistor (X101) is a germanium type so the pre-amp circuit values should be as per the 1st schematic.
With transistors the emitter voltage should always be less that the base voltage and in the case of germanium types by approx. 0.1 to 0.2 Volts (approx. 0.6 Volts for silicon types)
As a final check, with the fault condition present measure the voltage between emitter and base of X101, -ve black probe to the emitter, +ve red probe to the base, do the same for X201 as a matter of interest.
Lawrence.
ms660 is offline
Old 4th May 2020, 7:56 pm   #65
Paulus.d
x101 Emiter and base - .12 v X201 about the same.
Paul
Paulus.d is offline
Old 4th May 2020, 8:29 pm   #66
ms660
ms660's Avatar
I would replace the transistor.
Lawrence.
ms660 is offline
Old 4th May 2020, 8:39 pm   #67
Paulus.d
If I switch the transistors... then that should do the trick...
Are the original ones still available?
Paul
Paulus.d is offline
Old 4th May 2020, 9:18 pm   #68
ms660
ms660's Avatar
That depends if the other transistor is ok or not and whether or not the transistor in Ch1 is faulty.
I don't know if the originals are still available, a quick search will usually prove yes or no.
Lawrence.
ms660 is offline
Old 4th May 2020, 9:28 pm   #69
DMcMahon
DMcMahon's Avatar
Can be difficult to find these very old Germanium transistors, especially for a reasonable cost.
Would be worth asking the Forum on the "Sets, Parts and Service Information Wanted".
DMcMahon is offline
Old 4th May 2020, 9:44 pm   #70
DMcMahon
DMcMahon's Avatar
Were you able to verify the number on X201 ?
DMcMahon is offline
Old 5th May 2020, 10:40 am   #71
Paulus.d
X201 is Sony D64 .... Theoriginal component for the unit ....X101 is the OC140...
Does Tandberg series 15 have any compatable transistors? I have parts of that model
Paul
Paulus.d is offline
Old 5th May 2020, 10:59 am   #72
Paulus.d
Swapping them made no difference..... sound still fades away.... Paul
Paulus.d is offline
Old 5th May 2020, 11:36 am   #73
DMcMahon
DMcMahon's Avatar
The original X101/201 according to schematics is 2SD64, which is what your X201 Sony D64 is.
Your X101 OC140 as far as I can see is not an original, that is why I previously asked if there were any signs of its soldering having been disturbed.
I have not had time to check data sheets etc but according to radiomuseum.org (which is normally good) one of the equivalents for the 2SD64 is an AC176, which also according to radiomuseum one of the equivalents for the AC176 is an AC127.
Your Tandberg 15 should have a AC127 for transistor Q106 (in power amp stage).
There may well be many other Germanium transistors that would do, but it is always good ideally (if possible) to use the correct one or an equivalent.
DMcMahon is offline
Old 5th May 2020, 12:02 pm   #74
Paulus.d
The soldering in this thing is awful...it looks like every joint has been reflowed badly and where i've just touched it the tracks are coming off the PCB...
Both of my transistors seem to be working...or alternatively are both damaged as swapping them did not cure the problem..
Ill dig out the AC127 and try it , just to be clear in my own mind..
Paul
Paulus.d is offline
Old 5th May 2020, 2:05 pm   #75
Paulus.d
I've just cut the track at the wiper to channel 1's volume control and linked the wiper from channel 2 .....I can confurm the fault is only on channel 1's head pre amp ...
channel 2 is playing wonderfully .... I've also switched the head wiring too, so it's not the head.....
Paul
Paulus.d is offline
Old 5th May 2020, 2:28 pm   #76
DMcMahon
DMcMahon's Avatar
Good work, you are doing well !
DMcMahon is offline
Old 5th May 2020, 3:31 pm   #77
Paulus.d
Thank you... however keeping it playing while testing this has killed the Channel 1 pre amp..... there is now a very minimal sound from it ...
Paul
Paulus.d is offline
Old 6th May 2020, 1:19 pm   #78
Paulus.d
Well, that's it..... Channel 1 is finally working normally All down to C109 50uf 15v cap across R107 ....
One last question, I'm I doing any harm allowing Channel 2 tpplay without an otput transformer
Paul
Paulus.d is offline
Old 6th May 2020, 1:59 pm   #79
DMcMahon
DMcMahon's Avatar
Should be no problem, could remove the output pentode.
Cannot fully see how posts 75, 77 & 78 relate, but fantastic that you have fixed it, just need another output transformer now.
DMcMahon is offline
Old 6th May 2020, 2:09 pm   #80
Paulus.d
The channel 1 sound came back after a couple of tries.... i found a 47uf 16v cap so tried it in there ...it's still playing now
woo hoo
Paul
Paulus.d is offline
