Old 21st Nov 2011, 3:06 pm   #1
Pete_kaye
Pete_kaye's Avatar
Default Barbed-wire Aerial works well!
I made a simple 1 transistor plus diode set last year and tested it at home with a loft space aerial. Yesterday I took it out with me to test around the countryside near Sheffield. I found an ideal spot with a long length of barbed wire stretching about 80 feet horizontally to which I clipped the aerial and the bottom wire of the fence as Earth.
I got Radio 4 loud and clear where I would normally get a local station from 290M. If I left out the Earth, then I still got the MW station.
I had tried other locations which were not very good but the aerial was short. I pushed a screwdriver in the ground for earth and got limited MW reception if I stretched out a length of wire along a hedge.
The barbed wire was best! I am told this was used for clandestine POW radios in 1945, made in Japan.
Pete_kaye is offline
Old 21st Nov 2011, 3:27 pm   #2
mikelect
mikelect's Avatar
Default Re: Barbed-wire Aerial works well!
I didn't know the Japanese made Clandestine radios for POW's in 1945 ??
mikelect is offline
Old 22nd Nov 2011, 2:17 pm   #3
Tim
Tim's Avatar
I have heard barbed wire fences are/were used for telephone lines in the Australian outback. The fences used to run for miles of course, and the atmosphere is very dry so no easy path to the other wire or earth!.
Tim is offline
Old 22nd Nov 2011, 9:59 pm   #4
Herald1360
Herald1360's Avatar
Not tried barbed wire, but as a youngster, the overhead open wire disconnected telephone line which terminated on our house was a great crystal set aerial. It must have been about 200' from the house to the pole plus anything beyond that as well.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 22nd Nov 2011, 11:04 pm   #5
gavinhall
I'm presently using the old rediffusion cable which runs from my house to the hairdressers across the road then along to other houses. I've go 12 or so cores to choose from and it works exceptionally well.
gavinhall is offline
Old 23rd Nov 2011, 4:25 pm   #6
Pete_kaye
Pete_kaye's Avatar
Here is a photo of this great homemade set clipped to the barbed wire. It needs rotating anti- clockwise.
Old 23rd Nov 2011, 5:47 pm   #7
Station X
Station X's Avatar
Not any more.
Graham. Forum Moderator
Station X is offline
Old 23rd Nov 2011, 8:11 pm   #8
Ed_Dinning
Hi Gents, a tech question. Is barbed wire better than ordinary un-barbed galv wire?
If so what are the theories (and how about razor wire!!!!)
Ed
Ed_Dinning is offline
Old 24th Nov 2011, 12:02 am   #9
Herald1360
Herald1360's Avatar
Well it's more of a cutting edge technology, especially the latter
....__________
