Old 8th Aug 2015, 11:31 am   #21
jonmiller
Default Re: B9A Breakout Box
I got the B9A plugs from J.Birkett.
jonmiller is offline
Old 11th Aug 2015, 10:33 pm   #22
daviddeakin
daviddeakin's Avatar
What is this gizmo for, exactly? What do you plug into the red plastic sockets?
daviddeakin is offline
Old 11th Aug 2015, 10:57 pm   #23
MrElectronicman
MrElectronicman's Avatar
I like the idea, really neat.
I have a set up where I just connected the B9A to a terminal strip and the soldered the relevant bits and pieces to the other side of the strip. Did result in some instability on the odd occasion however
MrElectronicman is offline
Old 12th Aug 2015, 6:48 am   #24
jonmiller
Hello,
Thank you for the kind comments.
For daviddeakins post: primarily it allows you to bring out all the pins from the Valve under test, enabling you to measure voltages whilst the unit is powered up. Sometimes this can save a lot of time depending on construction of unit. It also simplifies which pin is which.
Old 12th Aug 2015, 1:52 pm   #25
frankmcvey
This was the version I mentioned earlier, which allows current as well as voltage checks without disturbing the equipment wiring.
Cheers,
Frank
Name:	Split adaptor.jpg
frankmcvey is offline
Old 12th Aug 2015, 3:50 pm   #26
jonmiller
Thanks Frank
Maybe for the next version
