Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Repair and Restoration Services Wanted
Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here.
Old 5th Jun 2021, 3:53 pm   #1
sweepthedog
Default Silvertone 6179 Radio Repair
Hi Everyone,
Here is a link to the thread
https://www.vintage-radio.net/forum/...d.php?t=180540
Basically I got a US silvertone streamlined midget radio for display, it was sold as electronically untested (Crackled but no reception) in the States, albeit it does look like it was restored recently. I tried it here but stupidly introduced it to UK voltage (240v) and no doubt may have burnt out some resistors/bulbs.
I am wondering if anyone with experience with radio sets, specifically US ones could give it a test and replace any fried components? Ideally, I would like it to stay as original as possible as the valves are dated 1939.
I like in York, North Yorkshire.
Cheers!
sweepthedog is offline
Old 7th Jun 2021, 1:11 pm   #2
Default Re: Silvertone 6179 Radio Repair
If you don't find anyone nearer you're welcome to send it to me, preferably minus the cabinet. Plastic cases don't travel well!
I'll warn you though that if you have burnt out the valve heaters the bill for new valves could be expensive.
Keep the soldering iron hot.
Station X is offline
Old 7th Jun 2021, 6:18 pm   #3
sweepthedog
I understand new valves are expensive and hard to find, so I would only want the bulb circuit replacing in that instance, especially as the valves are dated back to 1939 so would be a shame to lose them.
The valve heaters hopefully could have taken UK voltage for a couple of seconds moreso than the bulb or resistors.
Am I right in thinking a burnt out/failed resistor would stop the circuit to the valves and protect them if it was to fail first?
Thanks
Old 7th Jun 2021, 7:18 pm   #4
Thanks
Quite honestly I wouldn't like to say, it's possible just one valve's heater has blown. It's easy enough to test valve heaters for continuity using a Digital Multimeter (DMM) on ohms range. I'm sure someone could talk you through doing this test if you ask in your original thread.
Replacing valves, lamps and or dropper resistors isn't going to get this radio working, but the fact the speaker crackles is good news.
The bulb won't illuminate unless the valve heaters and the dropper resistors are good, but it doesn't follow that the valve heaters are bad.
Old 7th Jun 2021, 7:37 pm   #5
sweepthedog
Hi Graham
It doesn't crackle its completely dead so its mystery what it is.
Old 7th Jun 2021, 7:45 pm   #6
I thought the seller said it crackled?
Old 7th Jun 2021, 7:46 pm   #7
sweepthedog
Back in the states but it never once crackled here in the few seconds the light was on etc.
Old 7th Jun 2021, 7:52 pm   #8
It wouldn't have crackled because the valves wouldn't have had time to warm up.
Old 7th Jun 2021, 8:12 pm   #9
sweepthedog
Oh right, I am very ignorant with radios! Haha
So in that case the excess voltage might not have had long enough to damage them if they need to warm up
And hopefully a blown resistor or whatever is the only problem.
How long do they take to warm up?
Thanks
Old 7th Jun 2021, 8:24 pm   #10
This discussion will get us nowhere. It's all guess work and speculation.
You need to test the valve heaters yourself or find someone to do it for you.
Old 8th Jun 2021, 4:49 pm   #11
sweepthedog
Thanks. Is there anyone else near Yorkshire?
Old 11th Jun 2021, 5:04 pm   #12
The OP appears to have found a repairer, so I'll close this thread.
