16th May 2018, 8:19 pm | #1 |
TS 700G Kenwood/Trio.
Hi
I have just received an old TS 700G which is basically working. It will not transmit because the 9 pin plug that fits in the VOX socket is missing. Does anyone know the connections for the plug. I have a circuit and can make deductions but would like to be sure before trying it out. Thanks in advance, Chris G4BYZ |
16th May 2018, 8:48 pm | #2 |
Re: TS 700G Kenwood/Trio.
Last 2 pins on r/hand-side joined together.Looking at the pins facing upwards . Pins 8 and 9 to be precise. Look at it like a valve base.
17th May 2018, 10:08 am | #3 |
Thanks Hamish,
I thought that was the case but wanted to proceed with caution. Chris G4BYZ |
17th May 2018, 10:39 am | #4 |
Quite correct,I like certainty and these are a great rig,owned mine here since new.
Also the Nag144 Linear,which has not been used for years.Time to put up my Tennamast again.
