1st Jan 2010, 5:42 pm | #1 |
Handheld Transceiver greatest range?
Hello, I recently spoke with someone who said that his Realistic TRC-209 probably had the greatest range of any hand-held transceiver he's ever used, purely based on its 5 watts output. I think this was one of the old am sets. Reckons he can get about 7 miles to another handheld. This got me thinking about range/distance possible to ther handsets. I was surprised after a cursory check on the web that about a 7 miles range from portable to portable is about the best one can achieve, even with high-end models.
My question is, was it possible to achieve greater distances with the older type handheld transceivers before legislation kicked in sometime in the 70's-80's (handheld to handheld). It seems that one can buy these secondhand 20-30 year old transceivers for a snip of the price one has to pay for a modern equivilent, yet there is little difference in performance (output power/reception). |
1st Jan 2010, 5:52 pm | #2 |
Re: Handheld Transceiver greatest range?
Of course if you were a licensed amateur, I can remember when Schools contacted the Mir space station on a handheld, this would have only been about 5 watts......
From a CB point of view, Handheld range will always be limited - mainly due to the innefficient antennas fitted to the sets - not many people would want an antenna around 9 ft long on a plastic brick.... It is true that FM stuff seemed to have a shorter range - this is due to the way the system works - you need a fair bit of recieved carrier to detect FM, whereas AM the slightest sniff of a carrier is enough - the MK1 Ear is suprisingly good at weak signal stuff... Sean
1st Jan 2010, 6:50 pm | #3 |
It depends on a lot of factors. Atmospheric conditions, buildings in the way, curvature of the earth, AM or FM, location.
I got from Winter Hill to Holme Moss on a 5 Watt Maxon portable often, and from Moss to Pontop Pike on a good day. This was on FM. 169 Mhz or thereabouts. Cheers, Steve P.
1st Jan 2010, 8:06 pm | #4 | |
They are not pricy because they are illegal. A lot of these sets were imported from the US who have different regulations. Mike |
1st Jan 2010, 9:25 pm | #5 | |
This thread has been closed as it breaches forum rules.
