1st Apr 2015, 1:45 pm | #1 |
Please ID this PYE equipment (Help)
Hello all: Please can anyone can identify this piece of PYE Telecommunications equipment:
Only items on steel plate are SER#294 and Volts 100/240 all others are blank such as CAT No. -TX-RX- and FREQ-TX-RX It's blue (seems t be Galvanized metal) like stone wash. Seems to be a power supply it has DC posts on front that put out 26v DC and a very large black heat sink in middle. Only switch is toggle AC power on and a ON/OFF indicator bulb. Unit is solid state with a 1A fuse also on front. Its old but mint shape (beautiful) components like a large 10000uf Red capacitor quality English workmanship for sure |
1st Apr 2015, 3:38 pm | #2 |
Re: Please Id this PYE equipment (Help)
Hi Milton,
It is indeed a power supply, designed to run Pye (but will power other's of course) Radio Telephones, more info here: https://www.vintage-radio.net/forum/...ad.php?t=73237 |
1st Apr 2015, 5:09 pm | #3 |
Probably used to power "fixed mobile" equipment. This was a common practice and involved running a desktop mounted mobile transceiver from a 12V PSU sometimes with battery backup which was enabled by a relay which dropped out if the mains supply failed. Some units had battery input terminals for the connection of a dryfit 12V battery, which would be trickle charged from the supply.
Alan. |
1st Apr 2015, 6:00 pm | #4 |
Or in Green as Pye Power Supply: 5820-99-645-0123
1st Apr 2015, 8:30 pm | #5 |
It's from the Pye Cambridge era and I seem to recall that it might be a positive earth (chassis) device. Check before you use it with modern day equipment otherwise if the two come together you might see sparks!!
John G4IJD
Old radio engineers never die, they just go intermit...mit...mit...mit... |
2nd Apr 2015, 7:14 pm | #6 |
If it's putting out 26VDC i suspect the series-pass transistor's gone short-circuit.
As others have said, it's from the Pye AM/FM AM10 Cambridge era and should deliver 12-and-a-bit volts at around 5 Amps if it is healthy. |
2nd Apr 2015, 8:14 pm | #7 |
Well thanks very much for the info.. Yes I found the 26v reading on my multi meter strange indeed but assumed it was an English oddity Example (positive earth) the supply came from a friend who knows I repair electronics. And the only reason I hang onto it is the quality components and workmanship. I have no idea if it's worth anything or should be in a museum either way it's neat. Approximate age of these units? Again thanks folks. Cheers
3rd Apr 2015, 11:54 am | #8 |
Hi
These power units date from the early to mid 1960's. The transistors are probably Germanium types. |
3rd Apr 2015, 1:09 pm | #9 |
Yep, we had a Cambridge low band AM system in the '60s and a 5 watt mobile sat on our desk powered by a mains supply similar to the one shown. I still have the later F30 Westminster base station in my loft.
Peter |
8th Apr 2015, 10:32 am | #10 |
On the theme of identifying PYE stuff - anyone know what these are please?
8th Apr 2015, 10:45 am | #11 |
First thing is a dash-mount control-box and handset for an early "PTC" series radiotelephone from the 1950s. [The actual transceiver unit sat in the boot of the car and drained the battery at a prodigious rate]
See http://www.pyetelecomhistory.org/pro...chure-640p.jpg Second unit looks like a 24-to-12-volt dropper as used to run 12V radios in trucks, buses etc. Thick wires go to the battery and the radio; the thin wires are used to provide remote switching. Last photo looks like a slightly later transceiver [Vanguard? Reporter?] and control-box. http://www.pyetelecomhistory.org/pro...c-box-677p.jpg Last edited by G6Tanuki; 8th Apr 2015 at 10:54 am. |
8th Apr 2015, 6:52 pm | #12 |
Last picture is a boot mounted Cambridge and dash mounted control pod
8th Apr 2015, 7:00 pm | #13 |
The middle 3 photos are of the 24 to 12 volt convertor for the M290 series
Fred |
8th Apr 2015, 8:11 pm | #14 | |
I note in the same pic also a Whitehall head-unit. I rather liked the Whitehall. |
8th Apr 2015, 8:18 pm | #15 |
Thanks all, sorry I should have pointed out that in the third picture the unit of interest was just sitting on top of a Cambridge boot box and that the two things are not necessarily related.
From the caption it looks like it's a c-box (control box?) for a Ranger unit. Looks slightly different to the one in the picture though. |
9th Apr 2015, 11:24 pm | #16 |
The blue control box sitting on the shelf to the right of the phone in the last photo reminds me of a Whitehall type.
Alan. |
13th Apr 2015, 11:04 am | #17 |
Yes it is indeed a Whitehall control unit as mentioned earlier.
We also have a different type which seems to be for 2 Whitehall boot boxes - a VHF and UHF unit both running through the same head unit? |
13th Apr 2015, 11:13 am | #18 |
That's a later control-box - designed to work with a Whitehall *and* a UHF Westminster in 'talkthrough' mode so users with low-power UHF walkie-talkies could [Pye PF-series] could use the Whitehall as a cross-band repeater. MetPol used a number of these, as did the Civil Nuclear Constabulary.
11th Nov 2016, 1:16 pm | #19 |
Thread reopened at member's request.
11th Nov 2016, 2:19 pm | #20 |
Many thanks.
PYE PTC 114 images, as per request: |
