#2241 |
Thanks to yestertech (Andy) for the R2R drive belts that safely arrived recently.
David |
#2242 |
Thank you JackRae for BT Hub, very grateful.
#2243 |
Thanks to Keith (KeithsTV) for the projector and bulbs, I'll be looking at my 8mm films now.
Thanks, Jonathan |
#2244 |
Massive thanks go to G6ONEDave for sending me some lamps.
These will help to simulate the EE Lightning aircraft warming system 'Attention Getter' flashing lamps. These lamp units are not the right type, but are close enough for a practical demonstration to the public. Cheers, Scott
www.scottbouch.com |
#2245 |
Thankyou to Jolly 7 for the Grundig TN12 power adaptor that safely arrived today, it was very well packaged.
David |
#2246 |
#2247 |
My thanks to Nigel Vinylspinner and to Ken Ambientnoise for the offers of the Powersafer automatic power switch and the polystyrene capacitors, for which Nigel kindly arranged the transport. Now I'm looking forward to evaluating the power switch
- Julian It's good here
#2248 |
Many thanks to Ken (Ambientnoise) for the Bush TR82B - I'm looking forward to restoring it!
Andy |
#2249 |
Thanks to Christopher, high-vacuum-house, for the Denon CD player that I collected from RWB. Cleaned, serviced and running perfectly.
Also many thanks to Ken (Ambientnoise) for the Avo 8, working nicely. Thanks guys. |
#2250 |
Thanks to Nigel vinylspinner for a splendid assortment of many polystyrene capacitors- I'm sure that I'm in common with quite a few here in being grateful for his taking on the task of dividing up a vast number of these components, parcelling them up and sending them out to people on the forum,
Colin |
#2251 |
Thanks to Nigel vinylspinner from me too. I'm particularly grateful because I needed the capacitors to be posted, which probably tripled the amount of work involved.
Hugh |
#2252 |
Thanks to Nigel (vinylspinner) for the massive amount of work he has done in sorting, packing and posting all those poly caps for the benefit of forum members. Mine arrived today, a most useful selection.
#2253 |
I would also like to thank Nigel (vinylspinner) for the big box of capacitors that I received yesterday and think he should get a medal for the huge amount of time & effort he's spent distributing these to fellow forum members.
Andy
G-QRP #12697 |
#2254 |
I also want to thank Nigel (vinylspinner) for the huge box of poly caps received today. Beautifully labeled, packaged and posted. Much appreciated!
David |
#2255 |
Another huge vote of thanks to Nigel, (Vynilspinner) for the polystyrene capacitors.
Thanks for the immense amount of work you've put in to make these available to members. & saving them from the 'electronic waste-tip' where they could so easily have ended up! I second the medal award! David. |
#2256 |
Yes, huge thanks to Nigel for the work and time to sort, pack and distribute these capacitors. Also a shout out to VT Fuse (Mike) who took on the original task and request the help to sort and distribute. Great job chaps.
Mike
Leave me alone - I know what I'm doing. BVWS member, EUG, G-QRP Radio Bygones/Radiophile |
#2257 |
A special thank-you to Craig Sawyers for the Class D Wavemeter that arrived safely this week. A fitting companion to my 19 sets. Been after one for some time so thanks Craig!
Peter |
#2258 |
Many thanks to Ed Dinning for the valves. Well packaged. Only one duff one so all is good.
#2259 |
Massive thanks to Nigel (vinyspinner) for the awesome selection of capacitors sent! All organised into marked bags, it must have taken him ages to sort out!
A real philanthropic gesture, massive thanks! Cheers, Scott
#2260 |
Massive thanks to Jeremy ( Pamphonica) for the knob bright
the kindness of most of the people on this form is wonderful ! Thanks again Peter |
