Old 8th Nov 2011, 7:07 pm   #121
pitbuell94
Default Re: 819 line standards convertor.
Today, I make the first try of this converter ....
Nothing burn but no video on the screen display... only a blank screen.
In fact, the output of the converter give the right synchro signal for the 819 lines.
All the top synchro are OK but no video at all.
It seems to be that my interpolator don't allow to the video signal to go away.
Ok => I need to work harder now.
Good night.
Fred.
pitbuell94 is offline
Old 11th Nov 2011, 2:57 pm   #122
pitbuell94
Hi Daryl and PPPPenguin,
Do you know if the IO of a XILINX are 5Volts tolerant
I think I found one of my fault .
I totaly forget that XILINX is supply by 3.3 Volts and the LM1881 and TDA8708A by 5 Volts.
In fact, I put bridge resistor ( 20 kOhms and 10 Kohms) concerning signal from the LM1881 but I forget them for the output of the TDA8708A.
Did you make this mistake too?
My XILINX is a SPARTAN 3E 500K.
I hope I don't need to buy a new one.
Fred.
Old 11th Nov 2011, 3:36 pm   #123
ppppenguin
ppppenguin's Avatar
Spartan 3/3A/3E parts will survive 5V applied to a pin provided that the current that flows is not too great.
http://www.xilinx.com/support/answers/19146.htm
Google xilinx spartan 3e 5v interface or xilinx spartan 3e 5v tolerant for lots more information.
ppppenguin is offline
Old 11th Nov 2011, 5:41 pm   #124
pitbuell94
I PPPPenguin,
I think I burn my SPARTAN because only a resistor of 75 Ohms was in serie.
Only 5.5 mA is allow and I put inside a courant of 60mA.
I buy a new one
Frederic.
Old 11th Nov 2011, 5:52 pm   #125
ppppenguin
ppppenguin's Avatar
Try it. The Xilinx may have survived. They are fairly tough. If you have fried a few pins you may be able to use some other pins for your inputs.
Using high value resistors like 10K and 20K will not work well at digital video speeds. The stray capacity will severely modify the waveform. You should be thinking of a few 100 ohms.
Old 12th Nov 2011, 5:38 pm   #126
pitbuell94
It's seem to be that the design of my interpolator was totaly wrong.
When I check step by step the code, I found some errors.
In fact, no video output was possible
When the FIFOs were in read mode, the video was set to 0.
I try again next monday the new design.
the code below is the correction.
sel <= sync & vidon & sel_fifo;-- sel est égal à la concaténation de ces 3 signaux
with sel select -- action à effectuer sur sig_interpolateur_data_out en fonction du résulaltat de sel
sig_interpolateur_data_out <= "00000000" when "0000"|"0100"|"0001"|"0101"|"0010"|"0110"|"0011"|" 0111",--niveau synchro
data_fifo_1 when "1101",--signal video fifo1
(('0' & (data_fifo_1(7 downto 1))) + ('0' & (data_fifo_2(7 downto 1)))) when "1111",--signal video fifo1 et fifo2
data_fifo_2 when "1110",--signal video fifo2
"01000000" when others;-- 1000, 1100, 1001, 1010, 1011
Have a nice week-end.
Fred.
Old 14th Nov 2011, 1:38 pm   #127
pitbuell94
Today is a good day.
After changing the wrong code, some correct video signal appears at the output of the converter.
The XILINX SPARTAN is alive even if I give it too much power
I try today to connect this video to a TV.
Fred.
Old 14th Nov 2011, 2:22 pm   #128
cmjones01
That's great news! Do post a photo, even if it's just a scope trace
cmjones01 is offline
Old 14th Nov 2011, 2:53 pm   #129
pitbuell94
Some screen shots from the scope.
In yellow, this is the signal of the synchro coming from inside the FPGA.
The frquency is visible and value is 48.84µs.
In blue, the video signal.
Fred.
ID:	58643   Click image for larger version
ID:	58644   Click image for larger version
ID:	58645   Click image for larger version
ID:	58646   Click image for larger version
Old 14th Nov 2011, 2:57 pm   #130
ppppenguin
ppppenguin's Avatar
Always good to see real signals. I cannot see any front porch (the gap between end of video and start of sync pulse).
Old 14th Nov 2011, 3:00 pm   #131
pitbuell94
I need togive someinformation concerning the 2 first screen shot.
There is a problem because as you can see, the value of the video signal is sometime, under the black level.
I make a mistake in my code driving the TDA8708a in mode 2=> see datasheet.
I unselect the video input during the blank period, so, the TDA8708 haven't the black level reference to run in mode2.
Now, the input is always set to 1 and as you can see, now the value of the luma signal is always above the black level.
The true test now is to connect TV.
In parallel, I build a JARDINE MODULATOR for the F8a channel.
I send soon photos.
Fred.
Old 14th Nov 2011, 3:04 pm   #132
pitbuell94
Hi PPPPenguin,
You're right.
I need to trim the code because my front porch is too short=>less than 1µs.
Fred.
Old 14th Nov 2011, 3:18 pm   #133
pitbuell94
Hi again,
I check again, but all is correct.
The value of the front proch is maximun 0.5µs.
I send you some data concerning what I use for the 819 lines driver.
I add some extra pic with more details.
Fred.
ID:	58648   Click image for larger version
ID:	58649   Click image for larger version
ID:	58650   Click image for larger version
ID:	58651   Click image for larger version
Old 14th Nov 2011, 3:21 pm   #134
pitbuell94
The data from 819 lines franch standart.
Fred.
Old 16th Nov 2011, 2:50 pm   #135
pitbuell94
The tests I make don't give good results.
When there is not 625 signal coming into the converter, the screen of my 819 TV is black.
THe synchro pulse are OK and there is no problem of bug display.
When I put signal, the synchro become strange.
Sometime, there some bad synchro pulse in addition of the normal pulse.
It's seem to be that the signal coming from the TDA8708a to XILINX is not good.
Normally, the LUMA value should move from level HEX"60" or 64 (decimal) up to 255 because I use the TDA8708 in mode 2.
After test, the value coming out from TDA8708 move from 0 up to 255 so, some luma information are equal to synchro line pulse.
What I can see is when I move in front of the camera, something change on the TV.
Did someone have any idea concerning the right path to use the TDA8708.
Thank you.
Fred.
Old 16th Nov 2011, 3:10 pm   #136
ppppenguin
ppppenguin's Avatar
The TDA8708 digitises the entire signal including sync pulses. You must remove all data below black level. You will need VHDL something like this:
if VIDEO_FROM_8708 < 64 then CLIPPED_VIDEO <= 64;
else CLIPPED_VIDEO <= VIDEO_FROM_8708;
end if;
You may also have a problem with chroma information on a composite input signal. This must be removed. The simplest method is an analogue notch filter. A more sophisticated method is a digital IIR but this is much more complex to design. In our professional designs Darryl and I have always used dedicated decoder chips such as the TVP5150(?) or SAA7113. Thes have all the necessary filtering, sync separation etc all in the single chip.
Old 16th Nov 2011, 3:16 pm   #137
pitbuell94
OK, I try it.
Thank you.
Fred.
Old 18th Nov 2011, 8:48 pm   #138
pitbuell94
Hi PPPPenguin,
I understand why my system don't run in normal way as soon I put a video signal inside.
I've totally forget that I need to clamp the video signal after the interpolator operation.
For these reason, the internal DAC convert the signal from 0 volt to maximun LUMA value and not from Black level value up to maximum Luma.
Because this, for all the value of the video signal less than the black level after the conversion, these value go true the ouptut without the addition of the synchro value.
The TV see multiple top synchro.
I send photos next time.
Fred.
Old 18th Nov 2011, 8:53 pm   #139
pitbuell94
Hi again,
In fact, I don't want to use the TDA8708A to digitise the complet signal.
I want to use the DAC just during the visible video period.
I don't use the TDA8708 during the other period.
I think I don't use the TDA8708 in the right mode.
It convert the signal from black level to top luma in signal from X"00" to X"FF".
I want a signal coming from X"64" up to X"FF".
Frederic.
Old 24th Nov 2011, 5:00 pm   #140
pitbuell94
Because I can't find a way to add in VHDL correct code to mix SYNC and LUMA, I take an other path.
I mix with transistors all these signal but even if the signal look good with oscilloscope, in real life, there is no picture on the screen...
There is some LUMA value under the blank valu...
The TDA8708 give good code on the output, the LM1881 give good data too.
Can any jitter on some signal cause some disturbance on the design?
Frederic.
