Old 12th Jan 2021, 12:52 pm   #1
Martin Bush
Martin Bush's Avatar
Default Cassette deck balance control
I am looking at various cassette decks to get an idea of what's out there and, thanks to the forum, am paying close attention to those with bias controls.
One thing I have noticed is that some allow you to alter the record balance.
Why would you actually want to do this? It's not like you can multitrack on them. Is there a good reason to look for a deck with this control or is it more a case of the manufacturer adding a feature to make them look hi-tec?
Martin
Is it live, or is it... no, it's live actually...
Martin Bush is offline
Old 12th Jan 2021, 12:59 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Cassette deck balance control
Some decks have a balance control, while others have dual concentric or separate input level controls. They're there to rebalance the L-R input channels if necessary or desired. Usually you would have both channels set at the same sensitivity.
paulsherwin is offline
Old 12th Jan 2021, 3:08 pm   #3
Martin Bush
Thanks Paul.
It's some years since I got hands on with a tape deck and I suppose that was a feature I erased from my memory
I know the purpose, but I suppose it also allows you to accidentally make an unbalanced recording of you leave it set incorrectly.
Old 12th Jan 2021, 3:48 pm   #4
Nickthedentist
Nickthedentist's Avatar
True, but as Paul says, every stereo cassette with manual level control makes some provision for making the levels on each channel approximately equal.
Probably most useful if recording from microphones, but it's not uncommon for some sources to be a bit off-balance (particularly pre-recorded cassettes!).
With a bit of practice, it's usually very obvious if it's set incorrectly as the meters will look lopsided.
Nick
Nickthedentist is offline
Old 12th Jan 2021, 6:11 pm   #5
Martin Bush
Fair enough.
I think it stood out as I was looking on specific models for bias and found balance more often. I've a fair bit of experience recording using mixing desks, multi-track recorders etc using balance or pan but I think the fact that I was studying the cassette decks closely made me think it was odd
Old 12th Jan 2021, 7:26 pm   #6
Nickthedentist
"Balance" seemed to crop up in the later (1990s onwards) models. Older ones just had separate L & R level controls, sometimes concentric and friction-locked.
