1st Jan 2021, 12:47 pm | #1 |
Halson radio rebuild.
I felt sorry for this wreck of a radio, on Ebay , but when it arrived I noticed it looked to be a later rebuilt chassis ,it still looked like a project for me though , I set about making a new chassis ,the old one was made of brass there were holes where they weren't needed a bit of a bodge job , I was thinking of making it 240 volt I needed 69 volt for the series heaters and 120 HT , I remembered I had some toroidal transformers , just the job having wound a few more turns to get the 120 volt ,there were several taps where 70 volts was obtained connected it to my newly built chassis , worked ok .A new cabinet was made from American walnut ply , which I had , luckily the ribbed front and top came away from the original case ok, two plastic windows were made to fit over the original dials which had shrunk and were a bit distorted, not sure about the knobs these were the only pointy ones I had and are a bit cheap and nasty ,now looking for some brown ones, Mick.
5th Feb 2021, 10:49 am | #2 |
Re: Halson radio rebuild.
Hmmm 164 views but not one comment , is it something I said Mick.
5th Feb 2021, 11:06 am | #3 |
Well I think you have done a fantastic job.
I think sometimes when a job is this well done there is little to say Cheers Mike T
5th Feb 2021, 11:16 am | #4 |
Thanks Mike, little is better than nothing , much appreciated ,I think Success stories tend to get overlooked , Mick.
5th Feb 2021, 11:23 am | #5 |
From picture 1 to picture 4 I can only imagine at the time & effort put into that radio. I'm quite envious!
A smashing looking set, gets a thumbs up from me
The difference between stupidity and genius is that genius has its limits. (Einstein) |
5th Feb 2021, 11:39 am | #6 |
Wow, that certainly was a rescue mission. I wish i had your skills, if that were in my hands it would have scrapped. All the best, Norman
5th Feb 2021, 1:49 pm | #7 |
Nice work! It is an attractive radio, I can see why you rescued it!
Regards Lloyd |
5th Feb 2021, 3:09 pm | #8 |
Just seen this post Mick, it must have got buried under subsequent threads and I missed it. This takes me back to 2006 when I bought just the case from one of these at the car boot. The case was covered in pastel green paint and had modern knobs stuck to the front, it was being used as an extension speaker with a more modern unit fitted inside. Like you I saw the potential in this design and set about a cabinet restoration. I deduced that this was a Halson N.S.40 from 1933, a very rare set, detailed info from Nostalgia Air. Not having the parts to rebuild the original circuit, I built one of Neil Purling's TRF designs using octal valves (close enough, just a bit more modern than the original UX based line up) and fitted it into the restored cabinet complete with new brass dial panels (still not got around to etching these). Good that your set is complete, very nice job.
Neil
5th Feb 2021, 7:18 pm | #9 |
Very nice and an excellent job.
6th Feb 2021, 5:04 pm | #10 |
Well done Mick, an excellent job that must have taken many weeks of hard work. Glad you were able to rescue that lovely cabinet. The shape of those knobs looks fine, if the colour bothers you give them a quick spray of brown paint.
Probably the reason it wasn’t noticed at the time was because you posted it on the morning of New Year’s Day when most people were recovering from the night before. Best wishes. Len |
7th Feb 2021, 1:41 pm | #11 |
that's impressive Mick! You are right, we don't give enough attention to Success Stories - must do better! I'm sure somewhere there are some brown pointer knobs - but not in my spare knobs box..
Keep up the godd work! Cheers Andy |
