5th Oct 2020, 3:18 pm | #1 |
Grundig TK 120E Checkout
Have been checking out my TK 120E that I very recently purchased.
A very basic mid 1960's, 2 track, single speed (3/ 3/4 ips) 3 valve mono unit with no tape counter and only a single 3 pin DIN. Externally looks pretty good condition and generally clean inside, apart from the heads that need a good clean. Some gluing required for the rotary selector switch where the outer metal ring has come adrift from the plastic body and the plastic disk below where the lamps shines up through a red window needs gluing back down to the recorder body. Powered up OK, reservoir, smoothing and grid coupling capacitors all checked out OK. All valve voltages look to be in right ball park. Mains ripple levels are low on the HT supply. Mechanically everything works and tape transport operation (without tape) OK. The motor pulley to flywheel drive belt was very stretched and very badly cracked and after getting ready to play a tape, the belt broke. So need to find suitable replacement belt. Switched to Playback there is quite a loud hum with volume and tone at high settings, will investigate that later. |
5th Oct 2020, 4:09 pm | #2 |
Re: Grundig TK 120E Checkout
Happy memories indeed, used to own one in the day, mostly for recording pick of the pops, good little performer.
Greg.
Picture, sound?, DOOR. |
5th Oct 2020, 11:24 pm | #3 |
Fitted a replacement drive belt for the motor pulley to the flywheel, official size is 128mm x 2.7mm , nearest I could find in my spares was around 130mm x 3.2mm
As expected was not easy, as you have to thread the new belt up through the small hole on the underside, once the capstan shaft bearing plate is removed. Because this belt sits below (when unit upside down) the flywheel to Take Up reel table drive belt, you first have to remove that belt from the small pulley at the end of the capstan shaft first to be able to get the replacement belt in correct position. I used 3 lengths of wire (electrical) looped over the belts, one on the underside to hold onto the removed flywheel to Take Up table belt, to stop it disappearing, while working on the replacement belt. The other 2 lengths looped over the replacement belt on either side of the flywheel to help locate/pull the belt around the flywheel and stop the belt disappearing under the flywheel. During all this, the flywheel moves around quite a bit, as nothing holding it at its bottom end (with the bearing plate removed). To get the replacement belt to go over the motor pulley had to remove securing screw and lift out of the way the PB/Record head hum cancellation/compensation coil. Playback of tape works well now. Rewind really struggles when the Supply spool is heavily loaded with tape, I think the friction between the side edge of the Supply reel table and the rubber on the motor shaft is poor, needs more investigation. Erase works OK. Cleaned heads and tape guides plus cleaned corrosion off capstan shaft. |
6th Oct 2020, 4:23 pm | #4 |
Having owned several they were never that good at rewinding. You can try polishing the guides and reducing the take-up tension which acts as a dynamic brake, but it'll nevre be perfect - it's part of their charm!
7th Oct 2020, 9:11 am | #5 | |
The guides have been well cleaned, although not polished as such. By finger pushing the Supply table to make better contact with the capstan shaft rubber it rewinds a lot better, so will try various things to improve the contact. David |
7th Oct 2020, 10:55 am | #6 |
My parents bought one of these back in 1967 for 29 1/2 guineas. I have now inherited it, and it still works well. Well, it did until I played some music on it for a friend's funeral a few weeks ago when the belt snapped after 53 years! I'm curious as to why yours has an 'E' suffix? I'm not sure, but I think mine was made in Grundig's Irish factory as there is a 'G' moulded into the case with 'IRL' in small letters inside it. I cured the poor rewind by putting a flat section belt snugly around the LH turntable. Cheers, Pete.
7th Oct 2020, 11:35 am | #7 |
Thank you Pete for the suggestion. I currently do not have any flat belts of right size but will as a test try a tight rubber band around the reel table.
The "E" only appears as "TK 120E" moulded on the rear plastic panel. From the attached Alard Roose Grundig listing the E signifies England which I assume means manufactured in England. http://www.taperecorders.nl/JAAR.htm David |
7th Oct 2020, 12:23 pm | #8 |
Isn't that G INTL = Grundig International?
Regards, Ben. |
7th Oct 2020, 1:21 pm | #9 |
An example of the G INT from mine.
7th Oct 2020, 2:51 pm | #10 |
Well, there's a thing! I've just checked mine, and it is indeed marked G-INT as in your photo. Plus, it has the 'E' suffix too. It's been in the house since '67 and I've only just noticed it. Doh! Apologies to all for the confusion. I've had a look at my TK149 and that is marked G-INT as well. Cheers, Pete.
13th Oct 2020, 11:33 am | #11 |
Fitted a temporary tight rubber band around the Supply Reel table and rewind now works very well. Even though band is tight it looks like with use the band may ride up/down.
Have ordered a bunch of miscellaneous flat drive belts, will fit one of these and see if still OK, if OK will fix by gluing to stop the drive belt riding up/down. Been exercising Play quite a lot and now Play is starting to struggle sometimes with the Take Up reel table stopping/stuttering, looks like the Take Up spool clutch may be too weak, will check it out. |
26th Oct 2020, 12:04 am | #12 |
Stripped down the Take Up reel table/clutch as the clutch is slipping too easily in Play.
There are 3 felt pads that can go in 9 holes, documentation states that the outer holes is the stronger clutch setting, could not see what hole position the pads were originally in. Have been having fun and games tying the pads (after cleaning everything) in different positions, really quite difficult to get the whole assembly back in and drive belt in position without the pads falling out (then have to restart from scratch) and really difficult to fit the circlip on the bottom of the shaft. Have done a number of iterations without really improving the clutch, becoming quiet a test of patience. |
26th Oct 2020, 11:48 am | #13 |
Been there, done that. It's fun isn't it? I can't remember how I did mine as it was a while ago. I may have removed the arm that the take up reel table assembly on then refitted it afterwards. But don't quote me on that! Good luck! Pete.
14th Jan 2021, 7:07 pm | #14 |
Trying again to get the Take Up clutch not slipping when Playing.
16th Jan 2021, 9:06 am | #15 |
After more iterations of the take up clutch adjustment have now got Play and FFD working well.
The previous temporary repair of fitting a rubber band around the outside of the plastic supply reel table has now become noisy during rewinding, due to the band position vertically slipping. Will try a couple of flat drive belts in place of the rubber band, may have to glue them on, to properly secure them. Playback sound is OK but at high volume control setting, hum can be heard so will check that out later to see if any easy fix. Recording still to be checked. The TK 120E only has a single DIN connector where the input signal connects to the control grid of the EF 86 via a 10k resistor (and capacitor) so is a microphone sensitivity input. For line input will need to use a resistor attenuated cable. |
16th Jan 2021, 11:34 am | #16 |
Have you tried simply roughening up the rim of the supply table to improve rewind?
Regards, Ben. |
16th Jan 2021, 12:44 pm | #17 |
Thank you Ben, no I haven't, I will try that first.
David |
1st Sep 2021, 9:50 pm | #18 |
Thread reopened ag OP's request.
Cheers Mike T
1st Sep 2021, 9:57 pm | #19 |
Getting back to this one to hopefully finish it before selling it.
Went to retest Playback and had no sound at all, then remembered that recently had borrowed the ECC 83 valve to use in my Murphy TR1 David |
1st Sep 2021, 9:59 pm | #20 |
