Old 12th May 2019, 10:11 pm   #1
leslie5555
Default Black box EL42 valve voltage measurements
Hi all
I have a Pye black box MK2 Amp with the ecc83 ez41 and two el42 valves.
I have checked the voltages on the two output valves as follows
Pin 2 = 291v
Pin 3 = 15.7v
Pin 5 = 298v
Pin 6 = 0v
Pin 7 = 15.7v
Pin 8 = 0v
Other valve
Pin 2 = 291v
Pin 5 = 297v
Pin 6 = 0v
Pin 7 = 15.7v
Pin 8 = 0v
Also the HT is 267v on one tag and 300v on the other
Are those measurements what should be expected?
Les
leslie5555 is offline
Old 12th May 2019, 10:54 pm   #2
martin.m
martin.m's Avatar
Default Re: Black box EL42 valve voltage measurements
The EL42 pin connections are as follows:
1 and 8 heaters
2 anode
3 and 4 internal connections
5 g2
6 g1
7 cathode
The two EL42 cathodes are connected together in this model of Black Box. The voltages you have seem about right.
Regards
Martin
martin.m is offline
Old 12th May 2019, 11:59 pm   #3
PJL
The HT is a bit high and the cathode voltage a bit low. However, the voltages don't tell you a great deal as the valves share the same cathode bias resistor so it is impossible to tell if they are well matched and taking roughly the same anode current.
You can roughly check the current of each valve by measuring the voltages from HT to each anode then (with power off) measure the resistance of HT to each anode and use ohms law to calculate the current. It is 'rough' because the resistance of copper wire changes with temperature and part of each winding is also carrying the screen current.
PJL is offline
Old 13th May 2019, 10:35 pm   #4
leslie5555
Thanks to both of you for your help.
Les
