20th Dec 2017, 7:06 pm | #61 |
Re: It's DAT again!
And the other pictures
All the very best, Tas |
20th Dec 2017, 7:25 pm | #62 |
Re: It's DAT again!
Hello Taz,
The set you gave me can be seen on a couple of my pics. John. |
21st Dec 2017, 12:58 am | #63 |
Re: It's DAT again!
The display is impressive, but what's impressed me most is your pristine clean and totally uncluttered benches! How do you keep it like that? In my workshop, every horizontal surface is covered with bits and pieces... and in many cases, several layers deep
21st Dec 2017, 2:50 pm | #64 |
Re: It's DAT again!
Sounds familiar!
21st Dec 2017, 3:39 pm | #65 |
Re: It's DAT again!
Hmmm! Some very careful framing of the photographs There is a Philips 570 in bits on the bench that you can't see in the photographs!
21st Dec 2017, 4:11 pm | #66 |
Re: It's DAT again!
But... not a nut, washer, scrap of paper, coffee stain, bit of fag ash, chopped-out waxie, crumpled circuit diagram, screwdriver or pliers to be seen! Hardly a TV engineer's workshop, methinks, but - go on, admit it - you've had a tidy-up especially for the photographs!!
21st Dec 2017, 5:13 pm | #67 |
Re: It's DAT again!
It's called 'Christmas Cleaning'. Often carried out by ladies of the house just prior to Christmas. They didn't like hanging the Christmas decorations 'over the muck!' Probably not so popular today. John.
21st Dec 2017, 5:22 pm | #68 |
Re: It's DAT again!
No-one of the lady gender is allowed in my workshop, and the fact that I can always find things where I last left them and never lose anything in there confirms the wisdom of this policy. I find that those large yellow and black "Danger of Death" warning notices are very effective in deterring any non-compliance!
Oh, and with two vacuum cleaners in there, it's clean too. Untidy, maybe, but clean
21st Dec 2017, 5:24 pm | #69 |
Re: It's DAT again!
I have long been a believer in the statement that 'an empty bench (or desk) is a sign of an empty mind' . I know that my benches (and any other level surface) soon get covered in tools, components, bits of old computer/tape recorder/radio, etc.
As for Christmas decorations (or in my case Newtonsday decorations, as that's what I celebrate at this time), I haven't put any up here. I do have -- somewhere -- 16 LEDs fitted to a string of tinsel. There's a PSU/driver box with it that links to a 16 bit parallel port of the DEC DR11-C or PERQ PERQlink flavour. I have a PERQ program that I wrote to flash various sequences on the LEDs. Total overkill, of course, but the sort of thing I do. Maybe next year I will have found it and got it running. |
21st Dec 2017, 5:29 pm | #70 | |
Re: It's DAT again!
As an aside, am I alone in thinking that 'spring cleaning' refers to an operation in the restoration of a gramophone or clock, and nothing else ? |
21st Dec 2017, 5:48 pm | #71 | |
Re: It's DAT again!
21st Dec 2017, 6:07 pm | #72 | |
Re: It's DAT again!
Cheers Nick |
21st Dec 2017, 6:55 pm | #73 |
Re: It's DAT again!
Here are my Christmas lights, left up and turned on once a year. This is the corner of the kitchen, count the radios and TVs!
21st Dec 2017, 7:12 pm | #74 |
Re: It's DAT again!
I like the electomagnetic pedulum clock!
It's almost as bad as what the estate agents called the 'living room' when I bought the house. It now has a row of 19" racks down the middle containing a PDP11, PDP8, VAX, etc.... |
21st Dec 2017, 7:58 pm | #75 |
Re: It's DAT again!
You don't find a water-cooled beryllium oxide shaker in many kitchens....
21st Dec 2017, 7:59 pm | #76 |
Re: It's DAT again!
22nd Dec 2017, 12:56 pm | #77 |
Re: It's DAT again!
Well into my workshop we go and here are my vintage lights.
Lee |
23rd Dec 2017, 2:19 am | #78 |
Re: It's DAT again!
There is definitely a certain something about the glow from the old-fashioned tungsten filament fairy lights that you don't get with LEDs. I can only assume it's because it's a broadband filtered warm white light as opposed to monochromatic. And even flimsily-insulated mains voltage wiring was probably less unsafe than the candles with naked flames that had preceded them .....
(My own tree has modern LED lights on it; but at least it has a proper eclectic mix of different colours and sizes of ornaments, including home-made and edible ones. Not like those awful one-colour monstrosities you see in some shops ..... and it has proper tinsel, not those nasty string-of-bead things.) One thing I do find slightly disappointing with modern LED lights is that they seem invariably to be wired as only two phases; whereas LEDs could be wired effectively as four phases still using only three wires, byusing the self-rectification property as part of the multiplexing. This would give a more realistic "chasing" effect with a clearly-defined direction, and allow two colours to be displayed at different brightnesses. But I suppose I'm just being picky here; after all, the Sun is going to be coming back again in the Spring, our fancy illuminated displays notwithstanding .....
23rd Dec 2017, 6:18 am | #79 |
Re: It's DAT again!
23rd Dec 2017, 3:04 pm | #80 |
Re: It's DAT again!
Well Phil, yes I did have a tidy up before hand as it was a complete s...hole! It still needs work and then it'll be calm enough for me to concentrate!
