1st Jul 2020, 2:39 pm | #1 |
Which transistor
Which transistor can be used in reverse, ie E&C reversed with B staying the same. A bit like the FET 2N3819. Needs to be low power 2ma switching transistor.
TIA John.
My favourite text message "I'll be there in five minutes, if not read again" Last edited by 60 oldjohn; 1st Jul 2020 at 2:49 pm. |
1st Jul 2020, 3:56 pm | #2 |
Re: Which transistor
For myself, I'll be surprised if such a transistor exists (apart from a faulty one!). But I'm curious: why do you ask this Q.?
Al. |
1st Jul 2020, 3:58 pm | #3 |
There are a few that are pretty much the same both ways round, but I can't remember the type codes at the moment.
1st Jul 2020, 4:06 pm | #4 |
I recall an episode of the regular "In the Workshop" feature that used to appear in, I think, "Television", where a pair of reversed bipolar transistors was used to make a low power multivibrator that ran on low voltage supply with a low power consumption, but can't remember any details. It was the first time I had come across anything indicating that it was possible.
1st Jul 2020, 4:19 pm | #5 |
I seem to recall that there was a special transistor developed for use in early computers which would fit the bill, but like paulsherwin I forget its type number. I don't know whether this helps you at all. Possibly OC1??
Eddie BVWS Member. Friend of the BVWTM Last edited by eddie_ce; 1st Jul 2020 at 4:20 pm. Reason: additional information |
1st Jul 2020, 4:52 pm | #6 |
Further to my last these transistors may have been used in commercial TV standards converters. Or am I barking up the wrong tree?
Eddie BVWS Member. Friend of the BVWTM |
1st Jul 2020, 4:59 pm | #7 |
I think point contact types can be used either way on low voltages, but the gain is better the right way round.
EDIT: There's a bidirectional one here (page 49) Brimar TS7: https://worldradiohistory.com/BOOKSH...e-Sinclair.pdf |
1st Jul 2020, 5:12 pm | #8 |
Could you put two in inverse parallel? Bear in mind VBE is limited to but a few volts.
1st Jul 2020, 5:19 pm | #9 | |
John.
My favourite text message "I'll be there in five minutes, if not read again" |
1st Jul 2020, 6:08 pm | #10 |
It probably wouldn't have very good characteristics. To get good performance bipolar transistors are deliberately asymmetrical - highly doped emitters to get a high emitter efficiency, lightly doped collectors.
I guess a symmetrical valve wouldn't be very useful either? |
1st Jul 2020, 7:45 pm | #11 |
I think (from memory) that OC139-140-141 [all NPN] were designed to be 'reversible'; and I also seem to recall that OC41-42-43 [all PNP] were at least a little bit 'reversible'. (And, of course, all are germanium, too).
But cosmic rays over many years may have corrupted my memory . dave
Dave Teague |
1st Jul 2020, 7:54 pm | #12 |
That's likely, they're used in switching circuitry, not analogue.
1st Jul 2020, 7:57 pm | #13 |
There was a bunch of 'reversible' PNP transistors produced back in the 60s and often used as things like relay/solenoid-drivers in first-generation electronic telephone exchanges: these invariably had low-gain [Hfe of 30?] but were cheap so obviously attractive to designers when you needed two of them for every subscriber-line.
CV7343/BCY30? I've got a bag-full of them here, manufactured by Texas Instruments Bedford if the codes are to be believed. |
1st Jul 2020, 7:59 pm | #14 |
The OC140 as used in the sample and hold part of the analogue BBC C06/501 625 to 405 line standards converter.
John |
1st Jul 2020, 8:00 pm | #15 |
2SC2878
Reversible but not symmetrical muting transistor: https://electronics.stackexchange.co...ric-bjts-exist David |
1st Jul 2020, 8:01 pm | #16 |
ISTR that the OC140/141 was used in bucket-loads in the extraordinary BBC/Pye TV standards converters in the read/write role where the reversibility was useful.
Edit- looks like jjl has a better handle on it than me! |
1st Jul 2020, 8:58 pm | #17 |
BCY30 series, they could be used with an NPN to make a level detector.
They were an alloy transistor and were limited in applied voltage in this mode as stated above. Used with a ZTX 80 NPN in very many timers associated with power line auto reclosers produced by Reyrolle Ed |
1st Jul 2020, 9:28 pm | #18 |
Just did a quick simulation with anti parallel BC547s, the gain was a bit more than half of one transistor and symmetrical. It works.
1st Jul 2020, 10:00 pm | #19 | |
Keith Beaten too it!! |
1st Jul 2020, 10:46 pm | #20 | |
John.
