18th Sep 2016, 9:42 am | #1 |
100V Line Transformer identity?
I have a RS components line transformer that dates from the 60's
Its part number is 21-773-1 RS have deleted their cross reference database. Can anyone please provide any information on this transformer. I think it has two 8ohm secondary windings labelled A-B and C-D. The primary has tags 1 2 3 4 5 Any help would be great. |
18th Sep 2016, 10:28 am | #2 |
Re: Line Transformer identity
Hi Mike,
Does it look like those two? Data sheet available from Electrocomponents, paer number R/N35A002F. Hope this helps. Stef.
Failing to prepare is preparing to fail ... |
18th Sep 2016, 10:35 am | #3 |
18th Sep 2016, 11:08 am | #4 |
The OP refers to a "line" transformer. I wonder if he means a 100V line transformer or an output transformer?
18th Sep 2016, 11:26 am | #5 | |
with 100V transformers, they look very similar.
20th Sep 2016, 9:38 am | #6 |
RS line transformer identity
I have an RS Components line transformer with part number 21-773-1.
can anyone identify this part and provide details of the windings. |
20th Sep 2016, 10:44 am | #7 |
Re: RS line transformer identity
A photo of the transformer would help.
Malc Scott |
20th Sep 2016, 11:09 am | #8 |
By 'line transformer' do you mean power transformer or line output transformer?
20th Sep 2016, 11:27 am | #9 |
Or even 100 Volt Line Transformer?
20th Sep 2016, 12:09 pm | #10 |
Hello,
Looking at my Radiospares catalogue for Aug-Nov 1970, there is a "100V line" matching transformer at 24/- (shillings!). This was before Radiospares became RS Components and adopted a part numbering system. The transformer has four primary taps to deliver l, 2, 5 or 10 Watts and the secondary has taps to feed 3 or 15 Ohm speakers: A B C & D. If anyone has an early RS catalogue, I suspect this transformer will have the part number you mention. Regards, Dazzlevision |
21st Sep 2016, 5:17 pm | #11 |
Thank you for all of your help.
It would appear to be the 100v matching transformer with a maximum output of 10 watts. This is lower than what I require but I have now been given a Reslo 100v line transformer . Part no LT202 which I hope may have a larger wattage tapping. I have just repaired a Vortexion 50w amplifier and basically I am looking for a 100v transformer that will provide 50watts into 8ohm for a junior school project. |
21st Sep 2016, 5:50 pm | #12 |
Re: 100V Line Transformer identity?
I've updated the title of this thread.
22nd Sep 2016, 10:26 am | #13 |
I may have transformer from a (quite new) scrapped PA amp; it is 'transistor output stage' to 4 Ohm-70V line-100V line. I'd assume the power amp circuit which fed it was 4-8 Ohm output impedance; looks 50 Watts-ish. Any use? if it is £5 + P&P and it's yours.
22nd Sep 2016, 12:43 pm | #14 |
If HiFi isn't a requirement, an ordinary 115V + 115V to 12V + 12V mains transformer will do well enough. A 50VA one like this:
http://uk.rs-online.com/web/p/chassi...rmers/0504256/ Primaries in parallel, secondaries in series for ~ 100:20 volts.
23rd Sep 2016, 8:28 am | #15 |
Those 100v line amplifiers are not intended to just power 1 speaker as you are with say, 50 watts they are for use with several speakers each with their own transformer running at 10 watts max.
28th Sep 2016, 10:16 am | #16 |
Does anyone recognise a Reslo 100v line transformer .Part no LT202.
It has two terminals on one side marked A B On the other side are four screw terminals marked 1 2 3 4 |
28th Sep 2016, 11:37 am | #17 |
Are you sure this is a 100V line transformer? Reslosound made microphone matching transformers with an LMT prefix.
29th Sep 2016, 9:11 am | #18 |
I am told that this came out of a loudspeaker cabinet.
In actual fact I have been given two with the possibility of making two cabinets to get the required 50 watts. I assume the A B terminals would be connected to the L/S and the 1234 provide the 100v tapping? |
29th Sep 2016, 9:19 am | #19 |
That sounds most likely. Usually the speaker side has connections for various speaker impedances and the line side has connections for various power levels.
