13th Dec 2014, 3:47 pm | #1 |
1-500MHz frequency counter
I've just bought one of those 1-500MHz frequency counters on ebay for £7.59 and it looks to be just the job but I don't recognise the small coax socket at the interface. Has anyone else bought one who can advise me on this please?
13th Dec 2014, 3:53 pm | #2 |
Re: 1-500MHz frequency counter
Which one?
I'm suspecting it will be a "SMA" connector - as used on mobile phones and wireless-routers. |
13th Dec 2014, 4:49 pm | #3 | |
If it is the one that Google popped up searching for
13th Dec 2014, 6:25 pm | #4 |
Thanks guys. I've ordered an SMA male to male connector with 1.5m of coax in between so I'll cut one of the males off and attach a suitable probe. It was not knowing what to call it that was the problem as is often the case.
13th Dec 2014, 6:53 pm | #5 |
Good grief, the SMA torque spanner will cost far more that the counter
B
13th Dec 2014, 9:42 pm | #6 | |
I do like the SMA, a small (large ish) connector that is common and therefore cheap, very good for internal stuff. |
14th Dec 2014, 12:18 am | #7 |
14th Dec 2014, 2:09 am | #8 |
Yes, tongue in cheek, though I have seen torque spanners used on SMA. I thought my 99MHz counter was good value at £15, but that was some time ago. Has yours been supplied with any guidance on the usable input level; too little or too much can upset them.
B
14th Dec 2014, 11:59 am | #9 |
No Bazz, no info at all. I was thinking of adding a zener to the input but need to know what the max is.
15th Dec 2014, 12:56 pm | #10 |
Have you any advice at all on what the max input voltage is likely to be Bazz? I have an old RS counter that will take inputs up into the hundreds of volts depending on frequency so I will only be using the new one for low level transistor circuits; checking oscillator frequencies, etc. I've trawled the net but surprisingly can find no info on this, considering the thousands that have been sold. There isn't even a manufacturer's logo on it!
15th Dec 2014, 1:29 pm | #11 |
These look quite good and I'm thinking of getting one myself as I don't have one and my 'friend' decided to sell his for next to nothing without offering it to me first!
Shall I risk it or wait for yours to arrive so you can report on how good it is - probably risk it. I think I noticed one with an even higher resolution for something like £24. Maybe not the same frequency range. |
15th Dec 2014, 2:02 pm | #12 |
I've just given it a try with a 10MHz crystal oscillator and it shows that as 10.0016MHz but I don't know how accurate the oscillator frequency is (It's just a 7490 divider unit).
16th Dec 2014, 8:49 am | #13 |
Beat it against a 10 MHz source (WWV) using a shortwave receiver. If it's just a loose HC49/U XTAL the accuracy will be low.
It's odd to have an SMA connector as a test socket. A BNC is much more convenient and way more common. Tjerk, 9ZZ |
16th Dec 2014, 6:15 pm | #14 |
Cheers Tjerk,
Yes, I'm going to do that. I'm just waiting for the male connector and coax to arrive. I'll report back when i've done that. Many thanks Jim M0JBJ |
17th Dec 2014, 3:46 pm | #15 |
I've got one on order - worth a punt at that price!
17th Dec 2014, 4:45 pm | #16 |
17th Dec 2014, 5:02 pm | #17 |
I disagree. I use SMA connectors a lot and it's a hassle to tighten the nut. Not a problem for (semi-)permanent connections. But the twist'n'lock bayonet of the BNC ("Bayonet Navy Connector") beats this over and over again, hands down. Usually I'm not going over 4 GHz, the limit for BNC.
Tjerk, 9ZZ |
17th Dec 2014, 6:12 pm | #19 | |
I did ask the question previously on the forum about affective ways of protecting the input but don't recall any exceptional suggestions. A pair of Schottkies side by side may be a basic approach. Something more elaborate would probably be nice in terms of keeping the input impedance high . B
17th Dec 2014, 6:19 pm | #20 |
It is quite sensitive Bazz. I've just hooked it up to this little oscillator I put together to test RF Germanium transistors (It goes from 8 to 20 MHz) and it worked quite nicely when connected to the 6-turn green coupling coil. As I said earlier I don't intend using it with high amplitude RF.
