3rd Apr 2014, 6:06 pm | #1 |
100n 'x' cap
Hi again
I have some of these - could I use as direct replacement of 0.1µf despite them being 'x's? Cheers R |
3rd Apr 2014, 7:33 pm | #2 |
Re: 100n 'x' cap
Do you mean X i.e. mains rated? They should be OK. Just bear in mind that X caps, having been optimised for one purpose, might have compromised on other issues.
4th Apr 2014, 8:51 am | #3 |
Re: 100n 'x' cap
I've regularly used 100n X caps as replacements for the hideous Rifa caps in old Tandberg tape recorders. The tend to have the same form factor (at least for machines that use PC boards), so they are basically a drop-in replacement, and can be found for nothing by pulling them out of old set-top box power supplies and equipment of similar size.
Although as Dave says X caps might not be optimized for Hi-Fi, they're still way better than the caps they are replacing in this case. |
4th Apr 2014, 12:44 pm | #4 |
Re: 100n 'x' cap
Better, unless the X caps in question are (RIFA) paper caps...
4th Apr 2014, 1:20 pm | #5 | |
Re: 100n 'x' cap
Best test such salvaged capacitors. I'd be surprised if there is any evidence of leakage, but not at all surprised if it was nearly open-circuit. |
4th Apr 2014, 2:01 pm | #6 |
Re: 100n 'x' cap
5th Apr 2014, 12:48 am | #7 |
Re: 100n 'x' cap
Caveat Emptor indeed.........
5th Apr 2014, 4:58 am | #8 |
Re: 100n 'x' cap
Sounds a good solution to disposal of dubious yet sought-after items when quite good ones such as
http://www.rapidonline.com/Electroni...acitor-10-5784 can be had for 10p each. Though if I had acquired a number of them considerably more cheaply than that and having a Megger to test them at 1kV or more and in the unlikely event of most passing, it could be a different story. |
