Old 2nd Oct 2012, 6:52 am   #1
bennybrc
Default .01uf capacitors
Hi
Could someone tell me the modern replacement for a .01 uF capacitor as I'm in the middle of restoring an old tape recorder.
Best regards
Ben
bennybrc is offline
Old 2nd Oct 2012, 7:51 am   #2
M0FYA Andy
Default Re: .01uf capacitors
Another .01uF capacitor?
Or is this a trick question?
Andy
M0FYA Andy is offline
Old 2nd Oct 2012, 8:23 am   #3
bennybrc
Not a trick question.
I get confused with the modern versions.
This capacitor has become very large!
Ben
bennybrc is offline
Old 2nd Oct 2012, 8:43 am   #4
It may be listed as 10 NF.
Station X is online now
Old 2nd Oct 2012, 8:57 am   #5
Sideband
Sideband's Avatar
I suppose what you mean are the modern preferred values of some components? In the case of .01uF, there is no difference other than the way the value may be printed so use a modern .01 which can be marked .01uf, 10,000pF, 10 nF (nano farad = 1000pF) or 103 (103 translates as 10, and three 000's). It's the voltage that is important so always use one rated the same or higher than the original. Most modern polyesters are rated at 630V and these are fine for vintage sets.
Some of the intermediate values like .02, .03, .04 and .05 are not available but you would use .022, .033 and .047 (.047 will replace .04 and .05). In many cases, the values are not overly critical (except perhaps in tone control circuits) so .047 could replace all of the intermediate values without having any adverse effect on performance.
Rich.
Sideband is offline
Old 2nd Oct 2012, 9:02 am   #6
This type question comes up again and again and again, so I've created this sticky thread:-
https://www.vintage-radio.net/forum/...ad.php?t=88767
Old 2nd Oct 2012, 9:09 am   #7
bennybrc
Hi
Thanks for the info!
I love this forum
Ben
bennybrc is offline
