Old 9th Jul 2019, 9:37 pm   #1
neutronic
neutronic's Avatar
Default Curious circular slide rule
Something surprises me.
I just bought this military slide rule for fun. (and it was cheap).
The backside gives most popular formulas.In top is the explanation for sin,cos and tn.
Instead of giving the right angle in 90 degrees,it says 1600 pro mile or 0/00.
What does this mean or is this normal in the military artillery?
Jard N.
ID:	186428   Click image for larger version
ID:	186429   Click image for larger version
neutronic is offline
Old 9th Jul 2019, 11:15 pm   #2
Andrewausfa
Andrewausfa's Avatar
Default Re: Curious circular slide rule
Nice rule, made by ALRO in Holland. The 'pro mile' bit is the same thing as something you may have heard called 'mils'. 1600 mils is 90°, 6400 mils to a NATO circle.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 10th Jul 2019, 10:20 am   #3
neutronic
neutronic's Avatar
Thanks Andrew.
I did not know that,I have no military background.
In fact,I found this slide rule while looking for one special model I knew from the past.
A pocket model made to the specifications by the firm I used to work for.
At one side the relation between L, C and frequency.
And at the other side a voltage across a resister giving a certain dB value.
Even today very useful
But this model is rather scarce.
Jard N.
Pictures:Alro 746 circular slide rule 6cm diameter
ID:	186439   Click image for larger version
