Old 9th Jul 2019, 12:06 pm   #1
MeanDumpsterCat
MeanDumpsterCat's Avatar
Default Pioneer RT-1011L Solenoids
Hello everyone!
I've run into a small problem with my RT-1011L.
Whenever the fast forward button is pressed, the brakes don't seem to get released and it will fast forward but very slowly and I don't hear the usual clunk of the solenoid.
A few months ago when I pressed FF it would take a few seconds for the solenoid to click and release the brakes.
Sounds like the solenoid has just gone bad to me but I've never really dealt much with them before. Is there an easy way of fixing them or do they need to be replaced?
It's also worth mentioning that if I press play or rewind and then fast forward it works just fine as the brakes have already been released.
Cheers!
MeanDumpsterCat is offline
Old 9th Jul 2019, 12:13 pm   #2
Station X
Station X's Avatar
Default Re: Pioneer RT-1011L Solenoids
Originally Posted by MeanDumpsterCat View Post
Hello everyone!
Cheers!
Never mind what it sounds like. Use you meter on a resistance range to check the continuity of the solenoid's winding/s.
I've yet to come across a solenoid which can't be rewound. Check that it's actually faulty first though.
Graham. Forum Moderator
Station X is online now
Old 9th Jul 2019, 12:20 pm   #3
MeanDumpsterCat
Yeah I will do. Looking around online it seems lots of people have this same problem too so it would not surprise me if a dead solenoid is the case.
Old 9th Jul 2019, 12:20 pm   #4
vidjoman
H
So it's unlikely to be a faulty solenoid. Probably a sticking mechanical part - sticky grease etc. Or maybe a dirty switch.
vidjoman is online now
Old 9th Jul 2019, 12:27 pm   #5
Station X
Station X's Avatar
H
That information was added just before I posted.
Old 9th Jul 2019, 4:29 pm   #6
Lucien Nunes
The solenoids in this deck are controlled by a transistorised voltage regulator that allows a burst of full current to pull them in, then a reduced current to hold them with less heat dissipation. If the solenoids are reluctant to pull in there is most likely something wrong with that circuit, or with the mode switches and relays that trigger it and select which solenoids are to operate, or as mentioned sticky grease which is quite a common cause of sluggish operation of solenoid-controlled tape transports.
Lucien Nunes is offline
