Old 8th Jul 2019, 11:05 am   #1
SteveCG
Default TDA 1200B AM/FM radio chip
My question is this: does this chip have an intrinsic long term defect?
I have now encountered this chip twice, both in Roberts radios:
the FM3 and the Rambler II.
In both cases it is the AM section that has problems - for the FM3 low gain on both LW and MW, for the Rambler II no Local Oscillator or sign of life in the RF part either. For both of them the voltages on the pins are in agreement with the ST (a chip maker) application notes.
I've checked the switch contacts, looked for dry joints, etc.
I was wondering whether others have had similar experiences with this chip?
As an aside the only difference between the FM3 and the Rambler II seems to be that the printed circuit board is fully populated in the FM3 - with the tone button position on the Rambler II being the VHF button on the FM3. Both had a plastic frame loudspeaker and both used the TBA820M audio chip.
SteveCG is offline
Old 10th Jul 2019, 11:32 am   #2
SteveCG
Default Re: TDA 1200B AM/FM radio chip
A postscript thought:
Both the Roberts radios have a socket for an external power supply (9 volts). This, I note, has a -ve centre pin. This is rather unusual as most externally powered devices have a +ve centre pin. I just wonder whether an incorrectly polarized psu has been used and has damaged/taken out the TDA1220B chip?
SteveCG is offline
Old 10th Jul 2019, 3:00 pm   #3
julie_m
In the last century, negative centre was the norm for DC power inputs. Positive centre is a recent thing.
julie_m is offline
Old 11th Jul 2019, 12:43 pm   #4
SteveCG
Julie_m,
That there were -ve centre pin expecting equipments 25 odd years ago I can indeed remember. That it was the norm back then is something I was not aware of. Thank you for the info.
SteveCG is offline
Old 11th Jul 2019, 1:43 pm   #5
Boulevardier
It has always baffled me why manufacturers don't spend a few pence on a diode on the power input socket to protect against reversed polarity in supply... I just can't see that that tiny extra cost couldn't be accommodated... It's just about reasonable to expect Mr Average to check correct voltage from a wallwart - polarity is probably just a step too far for most people.
Mike
Boulevardier is offline
Old 11th Jul 2019, 7:06 pm   #6
AC/HL
AC/HL's Avatar
I suspect that most people use them on batteries, or if they want a mains supply they buy the recommended one from the original shop. Those who buy aftermarket either get it right first time or keep quiet about it. The worst are those reversible ones with the tiny embossed markings.
AC/HL is offline
Old 24th Jul 2019, 10:47 am   #7
SteveCG
An ordered TDA1200B chip arrived yesterday - ST brand. I've fitted it into the Rambler II and now have a working radio. My only comment is that of the challenge of removing the old chip!
SteveCG is offline
