28th Jun 2019, 2:29 pm | #1 |
Error when accessing eHam forums
Has anyone else had trouble accessing the eHam forums? I can get to the main site at https://www.eham.net/ and that is fine, together with most of the links from there. When I try to go to the discussion forums at https://www.eham.net/ehamforum/smf/ I get the error
Fatal error: require_once(): Failed opening required '/hubfuncs.php' (include_path='.:/hub/lib') in /var/www/html/forum/smf-110/index.php on line 54 Been like this for a couple of day. I emailed the webmaster but had no reply yet. |
28th Jun 2019, 2:33 pm | #2 |
Re: Error when accessing eHam forums
Works for me.
28th Jun 2019, 2:47 pm | #3 |
Works for me too.
28th Jun 2019, 3:02 pm | #4 |
Works for me, have you tried the usual clearing the web cache etc, very often cures problems. If you have passwords saved in the browser either know what they are or don’t clear the password section.
Frank |
28th Jun 2019, 3:20 pm | #5 |
OK, thanks. I will try clearing cache.
28th Jun 2019, 3:26 pm | #6 |
That seemed to fix the problem. Thanks.
Mods this thread can now be closed. |
