Old 24th Jun 2019, 10:46 pm   #1
Sparky67
Sparky67's Avatar
Default Luftwaffe Antenna Feed?
I was in France last week and took the opportunity to visit the old Luftwaffe KGr100 base at Vannes-Meucon airfield whilst passing through the area.
There are a few substantial concrete buildings left and a few hangars from the German occupation. On one building this caught my eye. It is about 9" square. Could it be an antenna feed plate?
Martin
G4NCE
ID:	185628   Click image for larger version
Sparky67 is offline
Old 25th Jun 2019, 2:00 am   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Luftwaffe Antenna Feed?
I'd have expected a large central hole for a glass or glazed ceramic insulating bush.
Ironically, I was at a friend's last week and he was machining-up an HF antenna feedthrough mounting to replace a missing one in a Dakota which once dropped parachutists and stuff over such places: "Night Fright" which is being restored to fly again. The actual plane his father flew back in the day! They hope to fly it to a D-Day remembrance event in the next year or so. Shame Britain doesn't do /AM amateur radio licences.
Radio Wrangler is offline
Old 25th Jun 2019, 10:01 am   #3
Herald1360
Herald1360's Avatar
Propriete privee
Ne pas monter
Now there's a challenge......
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 27th Jun 2019, 10:12 pm   #4
Sparky67
Sparky67's Avatar
My French is a bit rusty - as were four brackets spaced out on the roof which I spotted on a previous visit, which looked they they may have once held poles which could be raised and lowered.
I agree about a glass insulator. However, with what looks like an insulated plate and a brass thread and nut, the only other thing I could think it could be used for is a single HT / EHT feed?
I will do a bit of further research and see if I can turn anything up.
All the best,
Martin
G4NCE
Sparky67 is offline
Old 28th Jun 2019, 1:03 am   #5
emeritus
Does the close-up picture show two conductors? If so, could it be Pyrotenax-type mineral insulated electric cable?
emeritus is offline
Old 28th Jun 2019, 10:07 am   #6
HamishBoxer
HamishBoxer's Avatar
I think the French means,private property do not pass this point.
More precisely Do Not Go Up In The First Place.
No way that is an aerial feed.
HamishBoxer is offline
Old 28th Jun 2019, 11:22 am   #7
Radio Wrangler
It looks to be a steel plate spreading the force of five through bolts, probably to hold something on the inside. Perhaps a hook for a heavy medal bestrewn uniform or a very large pair of 'powerful gestapo binoculars'
Old 28th Jun 2019, 1:58 pm   #8
Herald1360
Herald1360's Avatar
Literally: Private property, do not climb (the staircase).
....__________
Old 28th Jun 2019, 6:27 pm   #9
Silicon
I assumed that the insulated panel was a piece of decayed Tufnol or Paxolin sheet.
It could have been put there after the war to seal the hole.
Silicon is offline
