Old 16th Jul 2019, 7:39 pm   #1
ajquiksilver
Default Valve amp identification
Hi I was wondering if you could help me. I found an old valve amplifier in a junk shop and wondered if you could help me identify it? I'd love to be able to restore it but have no idea what each wire is for what and what the knobs even do.
It turns on and left knob is power on then volume I presume. The right knob clicks into 3 positions. Not sure what this means it was used for?
Any help you could give me would be great. Even if its just some guidance on where to connect a speaker to see if it works!
Thanks,
ID:	186809   Click image for larger version
ID:	186810   Click image for larger version
ID:	186811   Click image for larger version
ID:	186812   Click image for larger version
ajquiksilver is offline
Old 16th Jul 2019, 7:43 pm   #2
Station X
Station X's Avatar
Default Re: Valve amp identification
That is, or was, a radio. Note the IF Transformers, tuning coils trimmer capacitors and cut out for the tuning scale.
What valves are fitted?
Graham. Forum Moderator
Station X is online now
Old 16th Jul 2019, 8:23 pm   #3
ms660
ms660's Avatar
6K8G, 6K7G, 6Q7G, 6V6G....6X5G?
The tuning capacitor is missing along with the tuning mechanism and tuning scale and the audio output transformer might be missing, other bits might be missing too.
The three position switch will be the waveband switch, originally it most likely would have covered the Medium Wave band, the Long Wave band and one of the Short Wave bands.
Lawrence.
ms660 is offline
Old 16th Jul 2019, 9:01 pm   #4
Sideband
Sideband's Avatar
Basically it's only any good for parts. It WAS a radio as already stated but has been severely robbed of essential parts. As it is, the valves might be worth selling on eBay for about a fiver each.
Sorry but it's useless as it is.
Sideband is offline
Old 17th Jul 2019, 3:11 am   #5
peter_sol
And there is no output transformer which would have been mounted on the speaker which is also missing.
peter_sol is offline
Old 17th Jul 2019, 8:54 am   #6
Cobaltblue
Cobaltblue's Avatar
It looks very similar to but not exactly the same as a Cossor 464 chassis possibly a 463
Most Cossor sets of this period had the supply taps on the transformer making me think this is an export model or possibly from a gram.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 17th Jul 2019, 4:03 pm   #7
Edward Huggins
For the sake of safely I would advise the OP to not attempt to plug in to the mains as it cannot work as it is. Leave well alone and sell as spares on ebay. It's not an amplifier anyway.
Edward.
Edward Huggins is offline
Old 17th Jul 2019, 4:57 pm   #8
Techman
Techman's Avatar
I totally agree with Sideband. It's the remains of an old radio and not worth bothering with, and is worth around a fiver for the valves and possibly the mains transformer.
Techman is offline
Old 17th Jul 2019, 5:17 pm   #9
paulsherwin
paulsherwin's Avatar
I also agree. You can clearly see the cutout in the chassis where the speaker would have fitted. It dates from the 1940s and is effectively unrestorable in its current condition.
Don't attempt to power it up, it won't work and you may get a shock.
paulsherwin is offline
Old 17th Jul 2019, 5:26 pm   #10
kalee20
When I saw the photos, I immediately thought, "Old radio, partially complete. No tuning capacitor, but RF coils and IF transformers still there, plus (obviously) valves and mains transformer."
No use as-is, though the valves look visually OK. If heaters are intact, may be worth advertising them on eBay or whatever, couple of quid each as otherwise untested.
kalee20 is offline
Old 17th Jul 2019, 6:37 pm   #11
crackle
If you bought this as a valve amplifier then I am sorry to say, you were done.
I advise like the others, that you dont mess with it just try and sell for £5 as spares.
Mike
crackle is offline
Old 18th Jul 2019, 7:26 am   #12
snowman_al
snowman_al's Avatar
Sad to say there appears to be more and more old radio chassis being sold as 'valve amplifiers' these days.
I guess a lot of traders actually do not know (being kind) what they do or do not have... It's got valves so I thought it was an amplifier?
Never Leave Well Enough Alone...
snowman_al is offline
Old 18th Jul 2019, 9:53 am   #13
Herald1360
Herald1360's Avatar
Three of the valves and the mains transformer and the chassis could be used with a quantity of new parts to make a simple low power (about 3 watts) amplifier. In addition, a new output transformer would be needed- about £15-£20.
Effectively, though, a complete and working radio with a "Gram" input already has this capability and is a radio as well.
Looks like we've lost the OP though......
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
