Old 14th Jul 2019, 10:56 pm   #1
Anthony_M
Default FRG-7 Quiet hum
Hi folks!
I had some troubles with my Yaesu FRG-7. One day it went silent. Found & fixed the problem - it was faulty rectifier diode.
While dealing with this issue, I've noticed quiet hum from speaker (when volume is at 0%, or antenna is disconnected). Maybe it was before - just didn't paid attention to it. It's more noticeable while using headphones or trying to record something with a laptop.
I've replaced capacitors. Not all (yet), but majority of them. Few difficult to access - left. But most essential ones (power supply) - replaced.
In everyday use - listening shortwave broadcast stations & hams with speaker - it's almost / completely unnoticeable. But using headphones at low volume levels (<5-10%) humming it's a bit annoying.
I've recorded that hum. Looked at spectrum - it's mostly 50 Hz tone (mains frequency in my country, I'm from Europe).
So... it's normal for 1970s low / mid-range shortwave receiver, or it's something else? Or it's OK and I'm way overthinking this issue?
Anthony_M is offline
Old 18th Jul 2019, 6:13 pm   #2
Keith
Keith's Avatar
Default Re: FRG-7 Quiet hum
Hi Antony,
I have an FRG7 and have never noticed a hum. I almost always use it on the loudspeaker though so it maybe only a problem on headphones. I guess one option would be to use lower sensitivity headphones or load the existing ones with a resistor. You would then need to increase the audio gain but the hum level should be reduced.
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 19th Jul 2019, 10:55 am   #3
AlanC
AlanC's Avatar
The power supply has a full-wave rectifier (D408 and D409) so any ripple should be at a frequency of 100Hz. So maybe you still have a bad diode?
Always expect the unexpected...
AlanC is offline
Old 19th Jul 2019, 11:59 am   #4
Keith
Keith's Avatar
As it's at such a low level, it's probably just capacitive pick-up by the audio stages from the mains wiring within the receiver.
Keith Yates - G3XGW
Keith is offline
Old 20th Jul 2019, 4:03 pm   #5
g4aaw pete
g4aaw pete's Avatar
Had this problem with two Kenwood R5000 receivers.
The cause was poor eathing on the IF / audio output pwb.
Resolution was by applying Deoxit to the earth return / mounting tabs.
Regards
Pete
g4aaw pete is offline
Old 20th Jul 2019, 5:36 pm   #6
Jon_G4MDC
Jon_G4MDC's Avatar
It might also be worth following the low level AF wiring.
It will almost certainly be in screened cable but it wouldn't be a first time to see it routed half a turn around the mains transformer with only small spacing.
Pye managed it in one transmitter.
Jon_G4MDC is offline
Old 22nd Jul 2019, 12:02 pm   #7
Richard - F4VPR
But here's another idle thought, the FRG-7, which is not exactly a Hi-Fi receiver, would have been "specified" with the Yaesu headphones designed for comms audio or a very ordinary 2" ~ 4" loudspeaker. Neither have any real response below 200Hz, but your everyday headphones designed for music and centre of the head thumping bass most certainly do. . . . . . . .
I doubt Yaesu cared too much about an ultimate low hum level. . . . . .
R.
Richard - F4VPR is offline
