29th Jun 2017, 6:35 pm | #1 |
Rubber Bench Mat
Can anyone suggest a source for a bench mat similar to the picture?
29th Jun 2017, 7:54 pm | #2 |
Re: Rubber Bench Mat
Some months ago I was looking for some rubber matting without it costing the earth, and bought a roll of 'Eva Floor Mat - DIYMATT' from CPC/Farnell, which I've been very pleased with. I have it on the floor in frony of my little metalworking lathe, which is a concrete floor and gets very cold in winter. I wanted something that would be easy to clean when swarf from the lathe falls on the floor and it's proved excellent in use. It's 2.25M long x 1.15M wide. The description states thus:
Quote: 8-< Ideal to use as a personal training mat in a gym, or for workshops, garage floors and play rooms. Heavy duty tough and durable floor mat suitable for general use. Provides an insulating comfortable and shock absorbing surface. Provides a cushion surface to hard floors. Water resistant and easy to clean. Anti-slip surface designed. Size: 2.25m x 1.15m 8-< End quote. http://cpc.farnell.com/kingfisher/di...ngdom%2Fsearch Not too expensive at £15.08 inc VAT post free. Hope that's of interest.
29th Jun 2017, 9:03 pm | #3 |
Philips did very similar, also a bench tidy, a lot of TV workshops had them, including the ones I worked at, excellent mats and durable.
Only thing I've seen of late that's similar is an ESD mat with a square grid, rapid online do them, but not cheap: https://www.rapidonline.com/bjz-c-18...-black-51-7682 Lawrence. |
29th Jun 2017, 9:16 pm | #4 |
I'll have to add mine to the house insurance!
29th Jun 2017, 9:39 pm | #5 |
Very much a "cheap and chereful" alternative (maybe), would a rubber car mat be any good? I've never used a bench mat, so not quite sure what the subtleties are that make a good one.
B
29th Jun 2017, 9:56 pm | #6 |
If it's the "organiser" aspect of the mat you're after, the Americans seem to do them much better than we do. There's one on Ebay, but it's hard to see because of the wrapping.
An image search for <rubber bench mat organiser> finds plenty of similar ones. Cheers, Frank |
29th Jun 2017, 10:16 pm | #7 |
Thanks for your input David, but it is the organiser type of bench mat I appear to be looking for. Thanks Lawrence but I can't justify spending over £53 on one which wouldn't get used a lot. I'm now thinking of making a small square wooden lattice and covering it with ¼" rubber band, the type used in fisher men's catapults. Didn't know they were called organisers Frank.
29th Jun 2017, 10:25 pm | #8 |
29th Jun 2017, 11:26 pm | #9 |
We had those Philips bench mats in the '50s, brilliant for not loosing screws on the floor!
Peter |
30th Jun 2017, 12:24 am | #10 |
I think the idea was that dropped screws etc. didn't scratch cabinets. Somewhere down the line I acquired the tidy, but not the bench mat.
30th Jun 2017, 6:52 am | #11 |
I still have & use my Philips bench mat.
I seem to remember that they weren't a cheap item when they were new, but it has stood the test of time, and has saved many parts from rolling off the bench and getting lost on the floor! SimonT.
The honesty of imperfection.......... |
30th Jun 2017, 8:24 am | #12 | |
If I'm disassembling anything I start with a clear bench top, put all the bits in clip-top plastic food containers, which I then misplace in the routine manner. Good luck in your quest.
30th Jun 2017, 8:26 am | #13 |
30th Jun 2017, 9:04 am | #14 |
Hi.
I was also looking for a suitable rubber bench mat a while ago and purchased some rubber matting from a local DIY trade outlet. It looked ideal for the job. The sting in the tail was the overwhelming smell that came from it, something that wasn't evident when purchased. It literally stunk out my workshop and I had no option but to return it. Has anyone else noticed the strong odour from modern rubber matting etc? I agree, the old Philips bench mats often seen in workshops were good. Those square grid mats are good but expensive. Regards Symon. |
30th Jun 2017, 9:52 am | #15 |
New rubber always smells. It can be either washed or even put out in the sun for a day or so.
Once the newness is off it will be all right. |
30th Jun 2017, 11:31 am | #16 |
I used one similar to this until a fellow enthusiast kindly gave me what you are seeking.
http://www.diy.com/departments/diall.../262197_BQ.prd Peter |
30th Jun 2017, 11:41 am | #17 |
I use an offcut from carpet underlay, placed with the rippled soft rubber side uppermost. The ripples retain screws, washers, nuts etc., and nothing gets scratched, if you are careful. It is also useful when working on electric guitars, as it protects the finish from being scratched or otherwise damaged. Go to a carpeting supplier and you will possibly get a suitable piece free.
Colin. |
30th Jun 2017, 12:05 pm | #18 |
30th Jun 2017, 12:21 pm | #19 |
That's what I used before I found pound shop non-slip rubber mat stuff, lots of other uses too
30th Jun 2017, 7:52 pm | #20 |
I was also going to suggest the stuff from Poundland. It is very handy stuff.
It may be difficult to find as it is displayed sometimes end on sometimes. Worth a try until you find a rubber mat for your purpose. As an aside , I thought it might also be suitable for a turntable mat if one missing as it is easy To cut to size. . Peter W ...Reelguy. |
