Reply
Old 7th Apr 2024, 3:24 pm   #1
beamcurrent
beamcurrent's Avatar
Default FreeView digital to analogue converter Goodmans GDR11
We have been donated one of these for our restoration of BBC MCR21 project. The idea was to use it so pictures could be displayed via the vintage analogue 405/625 line receiver installed.
The Goodmans converter box is useful as it has, as well as the scart connector the selected channel remodulated onto a UHF channel 52 in this instance although this can be changed in the set up.
So far so good!, however there is a problem with the aspect ratio. It can be set to normal 16:9 out or letterbox for use on a 4:3 tube or to "compromise" ?? (whatever this is meant to be?),.
The first two options are unsuitable and the third seems to produce the same letterbox as option 2. It was hoped that this might produce a pillarbox 4:3 display (sides cropped off)
The question is? does anyone have any experience of this unit and it's display modes? and can a pillarbox display be achieved.
Regards Brian
Visit the Virtual Broadcast TV Camera Museum
beamcurrent is offline   Reply With Quote
Old 7th Apr 2024, 3:56 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: FreeView digital to analogue converter Goodmans GDR11
Aspect ratios are a minefield with all boxes of this type feeding 4:3 TVs. 16:9 will show the 16:9 image with letterboxing. Zoom will throw away the left and right parts of the image to display a cropped fullscreen 4:3 image. I'd expect 'compromise' to crop to 14:9 with some letterboxing - this is usually the best choice for a 4:3 CRT TV and is what the BBC did for their analogue service.
Unfortunately it gets more complicated with 4:3 originated material. The broadcasters are supposed to switch the aspect ratio in the data stream, but most no longer do this and broadcast a pillarboxed 4:3 image in a 16:9 frame. This won't display sensibly on a 4:3 TV unless the digibox has been configured to zoom to fullscreen.
Basically, the broadcasters were heartily glad so see the back of 4:3 displays and now make no serious effort to accommodate them.
paulsherwin is online now   Reply With Quote
Old 14th Apr 2024, 2:11 pm   #3
andrewferguson
andrewferguson's Avatar
Not wanting to stray too far from the original post, but is the Goodmans GDR11 particularly good for vintage TV? (Or, say, do most freeview boxes of the era also have the equivalent features?)
By chance I picked up a GDR11 yesterday for about 50p in a bundle of other things. I was planning to Freegle it but if it's got features particularly suited to vintage TV I'll offer it here first.
andrewferguson is offline   Reply With Quote
Old 14th Apr 2024, 2:23 pm   #4
paulsherwin
Most Freeview boxes don't have a UHF modulator - the RF output is just passthrough. This is probably why the OP finds this particular model useful.
The amount of support for 4:3 screens varies between models. They all seem to do 16:9 with letterboxing and 4:3 with cropping, and many also offer the 14:9 'compromise'. A few allow the level of zooming to be specified, or allow the letterboxed image to be shifted up so the subtitles appear below the image.
Old 14th Apr 2024, 4:11 pm   #5
Richard_FM
Richard_FM's Avatar
I would have thought it was useful for anyone with an analogue TV with just an RF input.
Many years I bought one thinking they wouldn't be on the market forever, & have only occasionally used & still keep it in the original box.
Hello IT: Have you Tried Turning It Off & On Again?
Richard_FM is offline   Reply With Quote
Old 14th Apr 2024, 8:41 pm   #6
emeritus
I have three digibox models with modulators.
* Icecrypt T5000. This is the only one I now use for its modulator, for a small Philips pre-SCART colour set. It can be set to display a full screen 4:3 picture from a 4:3 letterbox signal, useful for watching TPTV. It also has undocumented menu settings for providing two types of European PAL, and one NTSC UHF output signals. I established the PAL option did work using a deceased relative's multistandard TV I had brought back from France.
* Ferguson FS01SDB (early model). This has a rectangular remote and the rear panel has an undocumented 9 pin D connector. The UHF modulator is fully tuneable.
* Ferguson FS01SDB (later model). This is actually model FS01SDBE, but this code only appears on the original carton and the cover of the user manual. Its front panel is identical with the earlier model, and bears the original FS01SDB marking. It differs externally by having a dogbone remote and no D connector. The modulator is tuned to a fixed frequency of 503.25 MHz, making it useless in my area, because that frequency is occupied by a digital multiplex. I guess it might be possible to disable the aerial input and just use it as a modulator by inputting video via its VCR SCART socket, but I haven't tried that. I use a couple of these with SCART-equipped sets. One is a 16:9 LCD set but I have been unable to make it display 4:3 pictures correctly.
The Icecrypt, which is used every day, started playing up a couple of years ago, but it was just a couple of leaking/bulging electrolytics in its power supply circuitry. I decided to replace the lot while I was at it, fitting high temperature types.
emeritus is offline   Reply With Quote
Old 15th Apr 2024, 6:16 pm   #7
andrewferguson
Great, I will give my GDR11 a test next week when I have more time, and (assuming it works OK) list it FOC in the offered section.
Old 20th Apr 2024, 1:30 pm   #8
colourking
Wishful thinking but I take it no terrestrial boxes with analogue modulator were ever produced that could receive HD / MPEG4 ?
Whilst no future switch-off date of SD/MPEG2 versions of the main channels on Freeview has so far been announced by BBC etc , it is probably something that will be ceased at some point?
(this has already happened on satellite/freesat)
They could though in the interm decide to downgrage the SD versions? With the result that a HD channel converted to analogue 625 has a better picture (especially with high motion footage) than doing so with a SD version of the same channel.
colourking is offline   Reply With Quote
Old 22nd Apr 2024, 12:07 pm   #9
locknut
I don't think so, but I'm sure there were a some freeview HD boxes with composite video out that could be connected via an external modulator or VCR.
Paul
locknut is offline   Reply With Quote
Old 22nd Apr 2024, 1:29 pm   #10
emeritus
The user manual for the Ferguson F01SDBE says that the SCART for connection to a TV provides Composite video (CVBS), RGB and Audio L/R.
Old 22nd Apr 2024, 11:28 pm   #11
Graham G3ZVT
Graham G3ZVT's Avatar
The F01SDBE appears to be only a DVB-T box.
Graham.
G3ZVT
Graham G3ZVT is online now   Reply With Quote
Old 23rd Apr 2024, 12:10 am   #12
emeritus
Sorry, didn't notice the HD, just had my cataracts done and haven't got new glasses yet!
Old 23rd Apr 2024, 11:08 am   #13
paulsherwin
Old Youview boxes are HD with analogue Scart outputs, but they don't have built in modulators.
Old 23rd Apr 2024, 12:10 pm   #14
Nickthedentist
Nickthedentist's Avatar
I'm sure my one (as recommended by Paul Stenning >10 years ago) did.
It was a Humax DTR-T1010 .
Could be wrong though, it was a long time ago.
Nickthedentist is online now   Reply With Quote
Old 23rd Apr 2024, 9:01 pm   #15
Robsradio
Funnily enough I bought a GDR11 at the car boot sale last Sunday for a quid, with box, remote and manual, I thought it would be ideal for the few analogue portables I have.
Robsradio is online now   Reply With Quote
Old 24th Apr 2024, 11:53 am   #16
locknut
I think it's just a loop through, no modulator. AFAIK.
There was an added peculiarity with the T1000/T1010, if you connect a display to the HDMI output, the analogue outputs stopped displaying any menu overlays.
Paul
Old 2nd Jun 2024, 6:27 am   #17
ortek_service
ortek_service's Avatar
I have an Icecrypt T5000 / bought several for my parent's VCR's etc that are used every day. They were one of very-few DTT STB's that had a 'Freeview channel number' display on the front, so didn't require checking via an on-screen menu that you were going to record the right channel (Plus also have upto 8 'wake-up' timer programmes you can set).
As they work with several VCR's OK, via SCART, it seems they do output composite OK on that (Especially as not many VCR's will accept RGB - or maybe YUV via SCART- With menu option to select video o/p as CVBS+RGB or CVBS+RGB(Off). As well as having a settable-channel RF Moduator.
They also have a fairly-good RF sensitivity, as will receive marginal signals that other STB's give-up on.
However these do have some issues:
1. The firmware seems to have had v.little testing, as I've found faults straight away. The most-common is that Programme Info is missing, but if you go into the TV-guide a select current programme, the info does appear.
Although sometimes (particularly if not selecting a channel on the same Multiplex as channel info is required for) the info won't appear until you change to a channel on the right multiplex / reboot the STB and go straight to required channel.
And never found any updates for it.
2. Sometimes there's a noticeable delay on the sound relative to lips moving on video, so looking like a badly-dubbed other-language programme. (Particularly occurs after many Rx-dropouts due to low-signal). So have to reboot to fix.
3. If you press buttons too-quickly on the remote, in certain combinations you can get the user-interface (or even reception of DTT signals) to crash, requiring a reboot to fix (sometimes even a Power-cycle, with standby-switch stopping working. Sometimes you can also change channel numbers on the front display, but software to tuner has crashed and it's stuck on one channel that would the same as display!
Pressing Mute then 'programme Info' does usually cause it to reboot, before the software has crashed, when you can tell its not behaving right (An intended 'feature'? - as also occurs on other makes / models).
4. It doesn't support QAM-256 that HD Multiplexess use, so can't receive those even for SD channels on some of these.
5. On screen Freeview Channel Info 'Signal Intensity' always shows around 86% even on an empty channel or one with good 'Signal Quality' - Which is the better indicator and needs to average >50% for reception to be free of dropouts / pixelation.
6. When deleting channels, to do a clean re-scan (rather than getting 'new' ones put in wrong places like > 700, you lose any repeating Timer programs.
7. With a later? version of the firmware, it defaults to auto-power off after 2hrs - Not very good if you've got a timed recording set that needs this.
Although you can disable this 'Eco feature', it resets to default after a power-cycle / all channels are deleted.
8. The Electrolytic capacitors do fail after about 6 yrs (Shorter if kept in a semi-enclosed 'Video cabinet'? so maybe could have done with a small internal fan) of continuous use (both original L-ESR marked ones, and salso imilar-spec replacements).
There are around Fifty Electrolytics in these, but fortunately the ones that fail are usually only those on the main two power-rails, after their rectifier diodes (often bulging, but some others that are in parallel can also fail and stop it working without signs of venting. Plus the 'startup' one in the SMPSU's mains-side, has been found to fail more than once in the same unit.
Reply
