Old 27th May 2021, 12:48 pm   #21
Jez1234
Default Re: Advice on this linestage build
Originally Posted by nzoomed View Post
Originally Posted by Jez1234 View Post
EF86 or better still EF184 in pentode form giving around x 400 gain followed by a cathode follower then wrap the feedback around the Baxandall network.
There are many ways of making a pre amp and hundreds of schematics on the web.
There will be plenty of designs from back in the day which you could just remove the phono section from. Beware of some old designs being intended to drive >100K load though! Keep the cathode follower.
If you didn't want tone controls I'd have linked to a design of my own intended for easy DIY build.
That sort of sounds similar to what Robert has suggested in post #14 except his is not a baxandall feedback loop, I may be tempted to go with something like that and source some EF184 tubes perhaps.
How easy is it to implement a bypass switch on a baxandall design? Ignoring the rest of my schematic on the first post, would that way of inserting a switch work? Will the volume level change significantly when switchong on or off the tone stack?
Originally Posted by Robert Gribnau View Post
I put this together (my suggestion in post #9 but with a cathode-follower after the tone controls).
Thanks for that, this looks similar to what I was looking at to begin with, but then I got onto the baxandall unity gain design and thought that may have been a better option, but if i can make this work with a baxandall layout, ill probably go with this.
FWIW after seeing reports of super linearity from EF86 when triode strapped I tried it....
It's not true! I tried several samples, tried different methods of triode strapping and experimented with load line etc and distortion was disappointing.
Thats interesting to hear, I have read from others experiences that if you feed negative feedback into a triode strapped EF86, that it improves linearity immensely.
Does that mean that an ef86 as a pentode has poor linearity?
I had a look at your first link and right down the page is Fig 11.1 which is what I was suggesting. Check out how tone defeat is done in usual practice and it should work fine here also.
6AU6 is used as the pentode in that schematic but many types will do the job, ideally with changes to resistor values for optimum operation.
Negative feedback (NFB) improves linearity of any device at the expense of gain.
Pentodes are intrinsically less linear than triodes as triodes have "built in" NFB which results in their much lower gain and lower anode resistance.
Alternatively the high gain of pentodes can be used to give high loop gain (high NFB) for excellent overall linearity.
Jez1234 is offline   Reply With Quote
Old 27th May 2021, 12:56 pm   #22
Robert Gribnau
Hello Jez,
I did not ask you for free R & D service. I asked you because I could not believe you can achieve a gain of 400 with an EF86 or an EF184 at line level.
From your reaction I now understand that additional circuitry is needed. But even than I still find it hard to believe. But hey, I am just an amateur.
About the distortion of an EF86 strapped as a triode: I find it hard to understand that an EE in audio and a Chief engineer at a (now defunct) hi fi company, like you wrote you are, needs to prove to himself that those claims were false. Furthermore I do not know of any Svetlana datasheet that claimes 0,1 % at 10 V output for an EF86 in triode mode but if you say so, it must be out there somewhere.
Robert
Robert Gribnau is offline   Reply With Quote
Old 27th May 2021, 1:14 pm   #23
Jez1234
Originally Posted by Diabolical Artificer View Post
Feeding an EF86with an active load improves linearity, just a MJE350 CCS. That said I don't mind a bit of distortion in my amps, else why use valves?
Andy.
I like to try and rival SS THD figures with valves
Old 27th May 2021, 2:38 pm   #24
Jez1234
Hello Jez,
Well lookie here... seems I have my first troll on vintage radio.net
It is easy to achieve gain of 400 from many pentodes. No "additional circuitry" is needed. Just a high value anode resistor and no appreciable load on it.
The Svetlana web site seems to be defunct. They are now made by a different supplier and just branded Svetlana and it seems they have gone to quite some lengths to remove all links to original datasheets etc and the current datasheet I can find is different from the original one... however here is a link to the relevant information, originally on page two of the datasheet http://users.telenet.be/tony.de.lobelle/toon/
<0.05% @ 10V RMS actually claimed.
Old 29th May 2021, 7:45 am   #25
Robert Gribnau
I stand corrected concerning the Svetlana claim.
My question about the gain of 400 from an EF86 and an EF184 at line level remains unanswered. I did not ask you about "many pentodes".
Calling forum members a troll is something you seem to do more often (on other forums and now also on this forum). My posting (# 22) was probably out of line. But it was caused by you asking for money to prove your statement (while we are in the "homebrew equipment" section).
Robert
Old 29th May 2021, 12:08 pm   #26
A quick look at the anode characteristic of the EF86 in pentode mode and low current shows an anode curve slope of about 2.4 Megohms can be achieved. With a Gm of 1.8mA/v this would imply a gain of 4320 would be available with a perfect current source biasing the valve, and an infinite impedance load.
This is clearly silly.
At the low current for the flat anode characteristic, Gm will be appreciably reduced to maybe 0.5mA/V so that gain is down to 1200.
But this is still assuming there is no load on the thing and so it is doing no useful work. The Zin of the following stage will bring the gain crashing down 220k will give us about 100 gain.
If the impedance is left high enough to get more gain, the effect of stray capacitance will bring the -3dB frequency point crashing down. Heaven help us if it's driving a bit of screened wire to apower amp, or a Baxendall tone control feedback network.
So, yes, very high gains are possible from an EF86, but under such impractical conditions that you can't really use them.
There is also the issue of the control of the anode voltage with constant-current source anode bias. There will be contention with the large anode impedance of the valve alone, and very poor control of the quiescent anode voltage.
Old 29th May 2021, 12:14 pm   #27
merlinmaxwell
merlinmaxwell's Avatar
Because they are pretty, that's why I built a few valve amps, now I use a TDA7293, works a treat.
Old 29th May 2021, 12:49 pm   #28
Jez1234
FWIW I've designed and built amps in which an EF184 was giving around x 400 gain.
A CCS was not a practical suggestion with a pentode for the reasons David outlines above but I have used bootstrapping to the same effect and without the DC issues.
Old 9th Sep 2021, 1:53 am   #29
nzoomed
Been a while getting back sorry, but here is my updated design based on roberts post, it has a switch to bypass the baxandall tone stack and had balance controls added.
Let me know what improvements can be made.
I may consider switching out the ef86 for an ef184 if its a better option.
Name:	new linestage.jpg
nzoomed is offline   Reply With Quote
Old 9th Sep 2021, 7:08 am   #30
I'm not sure what that circuit would do. Your final triode is a cathode follower configuration giving no voltage gain so the loop gain has to be below unity, and no inversion. So with positive feedback it isn't really the usual Baxandall circuit. The amount of boost is not going to be much at all.
Watch out for DC on your bypass path versus whatever the tone control network floats at. I'd expect operating the bypass switch to create a loud noise.
Old 13th Sep 2021, 5:35 am   #31
nzoomed
I see what you mean, when I inserted that baxandall stage into roberts schematic, it wasn't really designed for that kind of tone stack.
I dont need huge gain, as essentially this will be used as a buffer stage with minimal gain from mostly digital sources and an RIAA stage.
What can be done to prevent noise when operating the bypass switch?
Old 13th Sep 2021, 6:40 am   #32
Take a look at the circuitry around all switches. What sets the DC voltage on the circitry for each position?.... even when that position isn't selected? Because if the path is only AC coupled and relies on being switched in circuit to have a resistive path to ground, then when switched out the DC voltage can drift through stray leakage, capacitors can charge, a little (compared to the HT voltage, but an awful lot compared to the signal) and so when you next throw the switch you get a loud 'crack'. A while back, someone used the phrase 'tone stack' which is mostly used in guitar amp circles. This is the sort of thing where the amplifier tears the cones out of speakers.
So look particularly at all amplifying device inputs. What maintains precisely the same DC bias on it when switches are thrown? Even if all positions of the switch are OK, then what about when the switch is transitioning from one contact to the next? It's easy to have a valve grid or transistor base floating for a moment, and you can get a pop.
Often you have to add high value resistors around the place to bleed off any leaked charge, or to keep networks out of use charged to the same potential they run at when switched in.
Sometimes you have to add extra AC coupling and leak resistors just to keep things tethered close to ground.
Similarly, try not to let any DC run down potentiometer tracks. This is the most popular way to make them go noisy. Do not use the sliders of pots to provide ALL the DC setting of a grid. Add a fixed resistor grid leak. Pot sliders skip out of contact as they are scraped along the track, and floating grids quickly drift at DC, and this too makes for noisy pots.
These are things not taught on electronics courses. These are things picked up by designers who have been around the block a few times and have learned from their mistakes. These are things missing from a fair few hobbyist and magazine designs, and plenty of professional designs. But doing this is 'good housekeeping' and makes for reliable equipment which just works smoothly. Get this wrong, and though your amp might sound great when working normally, but if anyone switches the input or a tone bypass etc, the front row of the audience is blown back out through the foyer.
Even with a simple home hifi setup, you don't want even small clicks and pops, or scratchy pots.
Good housekeeping, attention to detail, call it what you will, it makes a big difference to the end user.
In ye olden days (tm) valves and transistors were expensive. So hifi designs did everything possible to economise on them. Where multiple inputs needed a mixture of different gains and even RIAA shaping, the usual ploy was to have the first device in the preamp have different feedback networks switched around them. These systems were a right devil to try to make pop-free and many designers didn't even know to try. Eventually as circuitry became cheaper, separate input stages were used for the different types of input, and the outputs of these stages were switched. Feedback paths were left carefully alone.
Switched feedback could be done fairly well, but it took a lot of care. Have a look at the arrangements in the Quad 33 preamp.
Old 15th Sep 2021, 5:15 am   #33
Diabolical Artificer's Avatar
After messing about trying to get a valve tone stage to work on one of my amp builds, I've come to the conclusion it's only an exercise for masochists. I've had great success incorporating Rod Elliots opamp based tone stage into a valve preamp and another amp, but the valve tone controls, sheesh.
The problem is you have high voltage DC going through pots or you try and block said HV with caps, but the caps add extra phase shift, which can make things unstable and implementing a bypass SW isn't trivial, as you've found, though I managed it with mine but differently to how you did it. Where you put the volume pot in the circuit effects things too, that's what I found. I used the circuit back in post one,altered a bit.
So in a nutshell I wouldn't use valves again in a tone control. A one two three four...so it's no nay never oh never no more, will I use valves in a tonestack, oh never no more ( all this sung at full whack to the tune of The Wild Rover) the experience aged me immensely : )
Andy.
Diabolical Artificer is online now   Reply With Quote
Old 15th Sep 2021, 12:15 pm   #34
wd40addict
wd40addict's Avatar
I'd have to disagree with Andy on this. Twice I've designed Baxendall tone circuitry for PA amps. One was active based around an EF86, the other passive. The important thing was that I simulated both circuits in Spice in context, with source and load impedances, and they both performed as expected once built.
Cutting and pasting a tone design into a different amplifier is not likely to be that successful.
Re the raw performance of the EF86 in pentode mode I once measured a gain of 200 with 0.1% THD. I didn't try triode strapped, but the idea (myth?) it has good performance in this mode dates back a long way. I remember a colleague who was an enthusiast back in the 50s telling me this.
wd40addict is offline   Reply With Quote
Old Yesterday, 5:14 am   #35
Perhaps that's the difference, having a level of knowledge to design a tone control from scratch is what I lack. That and most PA/guitar amp tone stacks I've seen don't care about DC in pots, it's cheap pots, low component count, price is King all the way. Oh, and the ability to use Spice.
Andy.
Old Yesterday, 5:59 am   #36
Spice is learnable. It's an answer to all sorts of problems rather than being a problem in itself. It is a fair step in learning it, but you don't have to absorb the whole thing in one go. You just need to do something simple and learn how to not turn on all the things you don't need. They'll wait til you have a use for them later.
The problem is that there are many half-assed simulators which look lots easier, and divert people from starting with a full-blooded one. They fairly soon hit the limitations of the 'easy' ones and get bored with them or frustrated. Some go on to look for and use a slightly more elaborate simulator and find they have to learn it from scratch.
It makes sense to curse a pox on all their houses and go learn one that will grow with you. If only it didn't look more difficult than it is....
Back to Baxandalls:
Peter Baxandall wrapped an existing sort of passive tone control around an amplifier such that its pots could swing between attenuating the input through to reducing the feedback and revving up the amplifiers gain. He'd created a circuit with fairly symmetrical capabilities. You could arrange one to be capable of as many dB of boost as it had of cut, and you could choose those limits. Rather neat, and it out-performed the passive version sufficiently that it became the dominant circuit for many years.
The passive circuit cannot give gain, so you must choose how much pseudo-boost you want with the pots screwed fully clockwise, and that is also the minimum loss you can have with it all set to flat.
Baxandall's active circuit has its limitations, too. It cannot provide more gain in the peak boost condition than the raw amplifier it uses can manage. Worse, the raw amplifier probably needs enough gain in hand at peak boost, that there is still enough feedback around it to help with its distortion and to control its output impedance. You can get a bit more gain per valve than you can get per transistor. Doing a Baxandall with the usual 12dB or so of boost doesn't look too bad with a good gainy valve, but the impedances you need to run fight you. With care, you can make something reasonable, but anyone doing distortion measurements with the pots much away from flat will help fuel the audiophile belief that tone controls are the spawn of the devil (FX: Thundercrack in the distance). Doing one with a single transistor is appreciably more difficult. Do-able it seems, but actually worse-performing.
But transistors have an ace, they are cheap and you can easily use two or more. You can have enough gain to make a good Baxandall without bad impairments at much boost, and you can avoid driving yourself down into the noise. You could have multiple valves, but the costs and heater power discourage people. Multi-transistor amplifiers are also availably in handy, easy to use, OP-amp form. You don't have to stick to the Baxandall curves, You can have parametric EQ if you want, like a zillion mixer desk channels around the world. You can even have, shhh whisper, a graphic equaliser (FX: BIG thunder crack!). Of course, that's being silly and going too far, but you can have one in your system. It doesn't need to be connected, just on power and lit up. It will then radiate its audiophile repulsion field and protect you from nuisance.
Old Today, 5:47 am   #37
Aye David, but to be honest I can't be ars*** to learn it, prefering hands on bench testing. Manipulating physical devices gives me FB via my hands and other senses, SPICE and other PC software is all in the realm of the head, like playing chess without a board. Not for me.
My rebuke to folk who don crucifixes and bulbs of garlic when encountering a tone control on an amp is my ears are fitted with LP filters, why would I not want to compensate for this filtering? We use Daddy's & Tomato sorse on our food QED. So I fit most of my amp builds with tone controls and use opamps, those handy gain triangles.
Andy.
Old Today, 7:06 am   #38
Spice is a tool. You don't have to use it all the time and for everything, but it's valuable if you have it so you can use it when you hit appropriate problems.
The funny thing is that there are many people with no real understanding of circuits who put something into spice and muck around with values or re-connecting thing almost blindly hoping to get something to their taste. Spice is a tool for simulating things and telling you what you've got does. It's absolutely lousy at steering you which way to go if what you get isn't good. It doesn't have a function which tells you "This circuit is a piece of crap, why not try a ....."
It comes into its own when someone has a bit of a clue about what's going on.
It allows you to try ideas out without burning through your stocks of components or using up much of your life expectancy.
Like any tool, used in the right circumstances it helps, in the wrong circumstances it can make things worse.
Did you use an electric drill to make all those holes in that chassis, or did you use a hand-powered drill, and file them all larger? You've made a lot of holes in chassis in the time I've known you on the forum. On the other hand, consider a food mixer/processor. It does a two-minute job in 15 seconds, then takes 10 minutes to clean for the next job. They don't mention that part in the glossy adverts. Not all tools are good, but some are.
Spice is a useful tool. It can help your understanding of circuits, and you're at a phase where it really would help you.
