10th Sep 2017, 2:37 pm | #1 |
Mystery Valve
Folks, does anyone know what valve this is, please ?
Have checked "Valve Museum" site, but no joy. Perhaps a "Barkhausen" VHF design ? Regards, David |
10th Sep 2017, 4:54 pm | #2 |
Re: Mystery Valve
Wild bit of straw-clutching- a low-power split anode magnetron diode, with a narrowed tubular bulb intended to fit closely in the pole-pieces of a powerful magnet and flying output leads to a balanced VHF/UHF load? The base looks something like a British B7? or similar early/mid 'thirties when a lot of this sort of thing was being investigated.
10th Sep 2017, 5:39 pm | #3 |
Re: Mystery Valve
Yep, definitely a B7 Base. Right enough, that narrow neck lends itself to magnetic poles fitment.
Just noticed - written inside, in white on the pinch is :- DTAS 260C, but nothing at all written on the glass envelope. No sign of a coiled grid structure. Regards, David Last edited by David Simpson; 10th Sep 2017 at 5:41 pm. Reason: Added info |
10th Sep 2017, 7:37 pm | #4 |
Re: Mystery Valve
think turretslug is closer to winning the coconut than clutching at straws! The French did a lot of pre-war work along with others on the split anode magnetron.
I have seen a few types like the one depicted but most people think of the Harry Boot/John Randall cavity magnetron which was produced by G.E.C whenever the device is mentioned. The lack of grid stricture confirms this,I did wonder if it was a gammatron briefly but the parallel section of bulb envelope suggests magnet pole placement. |
