Old 8th Feb 2018, 12:48 am   #1
Phil G4SPZ
Phil G4SPZ's Avatar
Default 'Record' Bond Tester (1944 and 1957)
Some readers may be aware of my strange interest in weird old test equipment, and this latest one goes perhaps further than any before!
I bought two of these units from the VMARS stand at the NVCF several years ago for the princely sum of £8. One instrument had a smashed Bakelite case but looked fairly clean inside, whilst the other was in better shape but had suffered badly from battery electrolyte corrosion. As I was looking for a meter capable of measuring resistance down to very low values, the scale of 0 to 0.1 ohm interested me and I hoped that I would be able to make a working instrument from the two wrecks.
When I got round to dismantling them, the full extent of the damage was revealed. On the plus side, I had (just) enough unbroken case parts to assemble a whole instrument. On the minus side, however, one movement was severely corroded, and the other had a broken ligament. I could also find out nothing about these meters at all on the internet so, after some fruitless research and starting to regret my purchase, I put the various parts into a box towards the bottom of the ‘to-do’ pile.
Recently, the chance acquisition and successful repair of a small Megger circuit testing ohmmeter reminded me of the old Record bond testers, and I resolved to have another look at them. More research revealed that my units were similar to an Evershed and Vignoles bonding tester, and some very helpful information including a circuit diagram was available on the excellent Richard’s Radios website. The movements are of the dual-moving-coil ‘Megger’ patented true ohmmeter type having a deflection coil and a control or restoring coil set at an angle to each other, but no hairsprings in the conventional sense. The coils are fed by two pairs of fine wire ligaments, which wind and unwind onto a barrel and so the pointer tends to float until the meter is energised.
Despite being badly corroded, the older movement (serial number 4382 dated 1944) still worked. I eventually fathomed out the circuit and with the aid of a multimeter identified the movement's connections and polarity, from which point I was quickly able to sketch out most of the rest of the circuit apart from the probes, which were missing. I started by removing the corrosion from the working movement, after taking advice from the Forum, using a de-scaling solution of equal parts of acetic acid and lemon juice, which was moderately successful. However despite taking great care and rinsing all the descaling solution away with boiled water, as I was reassembling the instrument I noticed that one of the control coil’s ligaments had become detached at its outer end. This wire is so fine that it is barely visible, and after some abortive attempts to solder it, I almost gave up on the whole project!
The other movement, serial number 5103 and bearing a ‘repaired’ date of 1957, was not corroded at all, but had a broken deflection coil ligament. The deflection coil carries more current than the control coil, and its ligaments are correspondingly thicker, being flat in cross-section rather than circular wire. Part of the ligament had disappeared, so I extended the fixed contact using a stiff copper wire to the point where I thought I could solder it onto the remaining section of ligament. After several unsuccessful attempts to ‘tin’ the tarnished end of the ligament, I took advice from the Forum again and it was suggested that I use a more aggressive flux. Eventually, and after much struggle and some profanity, I managed to make a good soldered joint. The movement had been brought back to life!
I replaced all the corroded internal wiring, fitted a paralleled pair of 1.2 volt sub-C size NiMH cells in place of the original alkaline NiFE accumulator that had caused all the damage, and lashed up a couple of test leads. The instrument then worked, but was reading far too high. A bit more research suggested that the original probes had internal resistances in them, although the values weren’t known. I tried experimenting with various values in series with the positive voltage probe feeding the deflection coil, and eventually settled on a value of 1.89 ohms (1.5 + 0.39 ohms in series) which gave very good accuracy across the whole scale range. I have some very low value 3% tolerance resistors, and on test the meter reads correctly and well within the 3%.
I read somewhere that four-terminal high current milliohmmeters of this type were designed for checking electrical cross-bonding links in aircraft, and originally came with heavy probes which rotated before closing a switch in the battery positive lead, thus ensuring that good solid contact was made with the resistance under test before the battery was switched on. In the absence of any details, I had to experiment and make something up, and settled for 0.75 sq mm two-core mains flex with simple crocodile clips as the voltage detector probes, plus a third ‘prod’ acting as the current injector. Accuracy is virtually independent of battery voltage or test lead resistance, within reason. The test leads are fitted with standard BS546 5-amp round-pin plugs. The earth pins aren't connected, and serve only to ensure correct polarity. The meter works with the leads plugged in to either socket.
I quickly discovered that it is vital for the voltage prods to make good contact with the resistance under test, as failure to do so causes a roughly 13-times overload which results in the meter movement being flung violently with a bang against the end stop when current is applied. If I’d had any worries about the integrity of my soldered repair to the ligament, it was dispelled by the time I’d done this on several occasions, and the movement survived... these things certainly are robust!
In use, the deflection coil behaves as a low-resistance millivoltmeter and the prods are clamped tightly across the resistance under test, before touching the positive end with the current prod. Battery current of anything between 1.7 and 2.0 Amps flows via the shunted control coil through the resistance under test, and the pointer indicates the resistance. For example, with 0.1 ohms across the prods, around 170mV appears across them which drives the deflection coil towards FSD. A proportion of the battery current also flows through the control coil, creating an opposing torque, and when equilibrium is reached the pointer indicates the ratio of voltage/current, hence behaving as a ‘true ohmmeter’ with its basic accuracy determined by its physical construction. I calculate that at FSD measuring 0.1 ohm, the 1 ohm deflection coil is passing 58mA with 58mV across it, and the 60 ohm control coil is passing 15mA with 950mV across it. Looking at the coils shows that they are wound with substantially heavier gauge wire than that seen in more conventional moving coil meters. There is, incidentally, no ‘zero’ adjustment on these movements other than bending the pointer where it is fixed to the moving coil assembly.
The final steps were cosmetic. The case is made up of very substantial Bakelite mouldings which responded well to polishing with Greygate No 5, and the scale window was removed, cleaned and refitted. All brass contacts were also polished. The instrument is quite heavy and was originally fitted with a leather strap as a carrying handle, fitting the two brass studs a bit like those on an Avometer. The studs are positioned towards the front of the case to counterbalance the weight of the original nickel-iron wet accumulator. I made a carrying handle from a scrap leather dog lead, but with the relatively lightweight NiMH cells I’d fitted, the instrument hung out of balance. I cured this by adding a small plastic bag filled with gravel in the large battery compartment! The meter including its leads and prods fitted neatly into a spare Avo leather carrying case.
If you’ve stayed with it thus far, you’ll probably be wondering why I need a meter that can measure resistances as low as 0.1 ohm. I do a lot of Avometer repairs. The 10 Amp range shunt in the Model 7 is 0.0125 ohms and that in the Model 8 is 0.05 ohms. I can now measure these accurately, as well as checking the resistance of the closed cut-out contacts, test leads and so on.
The Record Bond Tester is described in Air Publication A.P. 19744, which I've been unable to trace, and have an RAF reference number 5G/2126, so they were probably only ever sold to the Military and the vast majority were probably scrapped decades ago. Most of them were probably dropped and smashed, or ruined by the effects of spilled alkaline potassium hydroxide battery electrolyte. Judging from the complete absence of any pictures or information about these meters on the internet, I'm tempted to wonder whether I own the only working example in existence. Could this be a Record...?
A few ‘before’ photos are attached, plus the circuit diagram. Thanks for reading!
Phil
ID:	156988   Click image for larger version
ID:	156989   Click image for larger version
Name:	RBT movement 1944.jpg
ID:	156990   Click image for larger version
ID:	156991   Click image for larger version
Phil
Last edited by Phil G4SPZ; 8th Feb 2018 at 1:15 am. Reason: URLs and links added, plus clarifications
Phil G4SPZ is offline
Old 8th Feb 2018, 12:55 am   #2
Phil G4SPZ
Phil G4SPZ's Avatar
Default Re: 'Record' Bond Tester (1944 and 1957)
A few more pictures of the repaired movement, plus the meter 'in use'.
Phil
Name:	RBT movement 1957 repaired 1.jpg
ID:	156994   Click image for larger version
Name:	RBT movement 1957 repaired 2.jpg
ID:	156995   Click image for larger version
Name:	RBT testing 22 milliohms.jpg
ID:	156996   Click image for larger version
Name:	RBT testing 60 milliohms.jpg
Phil
Old 8th Feb 2018, 12:59 am   #3
Phil G4SPZ
Phil G4SPZ's Avatar
Finally, the finished meter, all polished up with its new handle and test leads.
Phil
Name:	RBT finished 1.jpg
ID:	156998   Click image for larger version
Name:	RBT finished 2.jpg
ID:	156999   Click image for larger version
Name:	RBT in Avo case.jpg
Phil
Old 8th Feb 2018, 2:35 am   #4
Boater Sam
Brilliant write up and dedicated work Phil.
Persistence and patience, the 2 vital skills, pay off in the end.
Boater Sam is offline
Old 8th Feb 2018, 11:37 am   #5
mark_in_manc
Thanks, I enjoyed that.
I think I might enjoy it all the more that such a pretty, well-made and accurate thing has such limited utility. When work-life can be so much about the bottom line, the innocent pleasures of (almost) futility are not to be underrated
mark_in_manc is offline
Old 8th Feb 2018, 12:23 pm   #6
M0FYA Andy
Phil,
Whilst 5G/2126 is undoubtedly an Air Ministry Section Reference, I don't think you're on the right track with A.P.19744.
I propose that that is an Admiralty Pattern reference, not an Air Publication number.
It's quite likely that these meters were supplied to both Services, so possibly a movement from an Admiralty example ended up in an Air Ministry example?
Also, I've never seen an Air Ministry item marked with an Air Publication reference.
I've attached an example of one made by Evershed & Vignoles in a wooden case, for interest.
Andy
Name:	5G-2126 Bonding Tester pic 1.jpg
M0FYA Andy is offline
Old 8th Feb 2018, 1:51 pm   #7
The Philpott
The Philpott's Avatar
A most excellent and bodacious item Phil (Evershed one rather nice as well- is that a factory seal on the screw Andy?)
I just had a speculative trawl thro' the ads at the front of the Air Force List for 1941, and as expected there is no Ad for the Record bond tester.
AP number, i agree, likely to be Admiralty Pattern number. Unfortunately a fairly comprehensive list for WW1 AP refs exists, but not for the WW2 period as far as i can tell.
I can realistically see a Bond Tester being heavily used and relied upon by both the Senior Service and the RAF, aircraft carriers and the fleet air arm certainly had a lot of salt spray to contend with. NiFe Cells are certainly something i associate with marine use due to their robustness and longevity. The CAM ship pilots in WW2 were the ones i feel sorry for- Hurricane goes up, chases a real or imagined Fw200 off, then ditches in the sea- no use for a bond tester there!
NiMh good choice- good charge density but not good charge retention compared to NiCd- you might need to gee them up if it's been idle for a while?
I can't imagine the ruckus caused if a fitter signed a bond tester out then left it on board an aircraft- Easily done in the gloom though.
Dave
The Philpott is online now
Old 8th Feb 2018, 3:14 pm   #8
McMurdo
McMurdo's Avatar
We used to get some of the aeronautical ones in for repair occasionally, and they also had the rotating probes; think of a pair of those hand operated pcb drills with a corkscrew, so as you push down the tip rotates and bites into the surface.
The ones I saw had 'gone digital' with early gas discharge starburst displays and cotton-covered twisted leads. They were made by former Westland subsidiary Normalair Garrett (pressurised cabin pioneers and instrument manufacturers) who are now part of Honeywell.
They were familiarly known as 'ducters'.
Kevin
McMurdo is offline
Old 8th Feb 2018, 10:07 pm   #9
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks to Sam and everyone for your interest. "Pretty" is an interesting description, Mark, although over the years I have moved from actively disliking Bakelite to positively admiring it. This unit is certainly a big, solid, heavy and beautifully-moulded lump of Bakelite, or bodacious as Dave so aptly described it, and it's obvious that a great deal of time and effort went into its design, no doubt paid for by its military contract price tag! Judging by the serial numbers of my two examples, at least 6,000 were probably made. I've e-mailed Record Electrical Associates twice now asking for any historical information, but they haven't replied as yet.
Andy, you could well be right about A.P. meaning "Admiralty Pattern" although I've been unable to find AP 19744 when searching for Admiralty reference numbers. The naval air service suggestion is a good one. I have an ex-RAF friend who runs a squadron association and he tells me that amongst their membership they have several ex-RAF aircraft fitters who may remember these units in service, so I'm waiting for his response. I've seen several pictures of the Evershed & Vignoles wood-cased bonding tester, which suggests that many more of these have survived than the Bakelite-cased Record equivalents. I would put money on the fact that the movements are identical, and probably made by E&V anyway.
Kevin, I think "Ducter" is or was a registered trademark of Megger Limited. I've seen it spelled "Ductor" too, and the term seems to be used generically for any very-low-reading ohmmeter, whether made by Megger or any other manufacturer.
Thanks again.
Phil
Old 10th Feb 2018, 9:54 am   #10
M0FYA Andy
Air Ministry Bonding Testers, including Stores Reference 5G/2126, are covered in a four-page Chapter of A.P.1095H, ‘Electrical Equipment Manual, Meters and Testing Apparatus’.
If anyone is interested, I’ll scan the four pages.
Andy
Old 10th Feb 2018, 10:20 am   #11
Phil G4SPZ
Phil G4SPZ's Avatar
Wow! Yes please, Andy, I would be really interested to see that! Thank you very much.
Phil
Old 10th Feb 2018, 11:28 am   #12
ukcol
ukcol's Avatar
Thank you for that interesting write up Phil, I really enjoyed it. Excellent "macro" photographs as well.
ukcol is offline
Old 10th Feb 2018, 11:30 am   #13
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks very much, Colin! Some of those close-up photos were taken through the lens of my illuminated magnifier. The camera is nothing more than an iPhone 6.
Phil
Old 10th Feb 2018, 11:52 am   #14
M0FYA Andy
Phil,
These are the four pages from A.P.1095H, I hope they are useful!
Andy
Old 10th Feb 2018, 12:23 pm   #15
Phil G4SPZ
Phil G4SPZ's Avatar
Andy, that is superb! Thank you so much for taking the trouble to scan and post the information. The probes are what I imagined, although the series resistors aren't shown. It is of course possible that with 60 feet of lead, the resistance of the cable was sufficient to ensure the meter remained in calibration. My Record instrument is the second one described. I think the first is the Evershed & Vignoles model.
Teriffic stuff, thank you again,
Phil
Old 10th Feb 2018, 12:42 pm   #16
M0FYA Andy
Phil, you're welcome!
I like to obtain copies of any APs, particularly those covering things electrical, either as paper copies or electronically.
You never know when they will come in useful.
Andy
Old 10th Feb 2018, 6:07 pm   #17
The Philpott
'Restricted- Official Use Only!' I wonder if a whole load of these instruments might have been on the receiving end of a purge and ended up being thrown in one of those apocryphal disused chalk mines we hear about..
Old 11th Feb 2018, 12:16 am   #18
Phil G4SPZ
Phil G4SPZ's Avatar
Could be!
Anyway, having had chance to study the A.P. kindly scanned by Andy, it's pretty clear that both the Record Bond Tester and the Evershed & Vignoles Bonding Tester are effectively the same thing, with detail differences but meeting the same Air Ministry performance specification "E&I.417". Knowing that both instruments were originally supplied with two test leads, lead 'A' being 6 feet long having a twin-spike probe and lead 'B' being 60 feet long with a single spike probe, makes it possible to put the final pieces into the jigsaw.
On Richard's Radios website, there is a picture of the interior of the 'B' lead probe from an Evershed & Vignoles instrument, and it contains two small spirals of resistance wire. I've been in correspondence with Richard and I hope he won't mind my including this link. It seems that these resistances were included to bring the total resistance of the leads up to the value required to ensure the instrument read correctly. I have no doubt that the Record probes contained similar resistances.
I don't know the cross-sectional area of the original leads, but if we assume that they were the imperial equivalent of 0.5 sq mm (the smallest mains flex easily available today) which has a resistance of 39 ohms per kilometre, then the combined length of leads 'A' and 'B' of 66 feet (20metres) would have a resistance of 0.78 ohm. As I've discovered by experiment with short test leads of negligible resistance, the meter needs 1.89 ohms in series with its deflection coil to read true, so the probe resistance would be about 1.1 ohms. I guess this design gave the manufacturer the option of making available shorter or longer 'B' leads, up to about 160 feet in length, by simply altering the value of the probe resistors and not having to change the instrument internally at all.
Thanks again for everyone's interest.
Phil
Old 11th Feb 2018, 9:21 am   #19
dseymo1
I do like the term 'exploring spikes'.
dseymo1 is offline
