Old 22nd Apr 2019, 9:16 am   #1
geeoboeh2s
Default Radio Interference Measurement Receiver
I have a Post Office designed Radio Interference Measurement receiver. When last used with its dedicated power supply it worked perfectly. However I no longer have the power supply.
The operating manual states that the power supply provides 250Vdc and 6.3Vac so I didn't anticipate any issues with evaluating its performance.
Power is provided to a 4 pin Jones plug and I readily determined the 3 pins for ht, heater supplies and common ground. The 4th pin is connected to the suppressor grid of the mixer valve, V4 on the circuit diagram. I need to determine the potential applied to this pin.
If anybody has the relevant power supply or a circuit diagram perhaps they could help or perhaps somebody has experience of mixers with the oscillator voltage taken to the suppressor grid.
Chris
geeoboeh2s is offline
Old 22nd Apr 2019, 11:37 am   #2
Leon Crampin
Default Re: Radio Interference Measurement Receiver
It looks to me as though the suppressor grid of the mixer receives the local oscillator output in order to function as a mixer. I suspect that the decoupled link to the Jones plug is there to enable the local oscillator to be disabled from the front panel, either to facilitate finding the source of any unusual "birdies" during measurements - or else possibly as an aid to the alignment of the IF stages of the receiver.
This looks like a very high gain receiver - what's the valve line-up?
Leon.
Leon Crampin is offline
Old 22nd Apr 2019, 12:31 pm   #3
ms660
ms660's Avatar
The connection to the suppressor grid will be for the bias voltage...11 volts -ve so far as I can make out.
Lawrence.
ms660 is offline
Old 22nd Apr 2019, 2:57 pm   #4
geeoboeh2s
Leon,
The receiver has 11 valves,
R.F stages, amplifier, mixer, oscillator are CV1091
If Amplifiers, CV1053(2) and CV1065 (1)
Meter detector CV1054
Calibration oscillator CV172
DC amplifier CV587
Audio CV587
BFO CV587
The unit is designed to detect and measure the amplitude of levels of interference, conducted and radiated. A rod aerial is included for the measurement of field strength in чV/m.
Lawrence,
Perhaps you could tell me how you arrived at -11Vdc for the suppressor voltage. It seems a sensible figure but I can't follow how you calculated it.
Chris
Old 22nd Apr 2019, 3:02 pm   #5
ms660
ms660's Avatar
Originally Posted by geeoboeh2s View Post
Lawrence,
Chris
Section 2.2.8 in report page 8 here:
http://www.digitalarchives.bt.com/Ca...B_226_2388.pdf
Lawrence.
ms660 is offline
Old 22nd Apr 2019, 3:31 pm   #6
geeoboeh2s
Thank you very much for the link to the Post Office document. It is far more comprehensive than the one supplied with the test set that merely says that the supplies are 250Vdc and 6.3Vac. A very confusing statement.
A 180R resistor in the grounded end of the ht line should suffice.
Chris
